    Page 9 of 12 FirstFirst ... 4 5 6 7 8 9 10 11 12 LastLast
    Results 161 to 180 of 242
      You must be siked being so close to driving it again.
      Dallas TX
      you are 100% correct
      Mothers day put a damper on things today but I did manage to get the hood sanded buffed and on the car. I knew it was bound to happen since the factory paint is so thin. I buffed the paint thin enough to see primer in a couple small spots.
      Aug 2008
      Pgh, PA
      Glad the progress continues! What are you going to do about those thin spots? Can you notice it real easy?
      Dallas TX
      Quote Originally Posted by wmhjr View Post
      Nothing for now. It just goes with the rest of the paint and gives it character. There are small rust holes on the bottom of both fenders rock chips on the door and lots of cracking / crazing on the rear deck lid. At this stage in the cars life the plan on the body was not to make the body and paint perfect just as good as I can with what I have to work with. If I don't end up selling it to build something else then I will perfect the body and paint in the future.
      It looks great all back together. Trim looks good too.
      Apr 2007
      Utah
      It is looking great. I bet it is exciting to be putting it back together.
      Sam
      Northern UT.
      '68 Camaro "Bodacious"
      '56 210 2dr "Buckshot"
      Dallas TX
      Well I had hoped to have it on the trailer today to drag it to work for an alignment. Then it would be just exhaust and a little interior before I could drive this weekend.
      Well last night added oil, coolant, gas, battery key power on everything works. Turn the key to start and nothing. At that point I just came inside and went to bed. So in the shower this morning I'm going through in my head anything it could be and all of the sudden My dumb ass never put a fuse in the not used power window circuit that I used for the neutral starter interupt relay. I bet it fires right up tonight.
      Aug 2008
      Pgh, PA
      You gonna record the first fire?
      Dallas TX
      OK for you die hard olds guys you will enjoy this and get a good laugh. For you Chevy guys working on Oldsmobile this may save you from killing yourself.
      Its been 14 months since I took my car apart. Well thurs night I planned on starting it so I could trailer it to work Friday for adjusting all the suspension before I can drive it. Starter was dead but I figured out it was a fuse issue with my neutral saftey system.
      So Friday night with the starter working I try to prime the carb but all I cab get it to do it blubber. I add a little gas over and over till finally the pump is primed but it just won't start. I move the distributor back and forth a little at a time but it just won't fire. I run the battery down trying and put the charger on it. I try another 15 min and see a small fire reflection from the raw gas in the open exhaust manifold so I just call it a night.
      So today I start about 1:00 and add a temporary exhaust a few feet behind the motor so I don't have any more potential fires. I check the timing I check for spark I check the compression incase some how sitting the rings stuck. I try a differnet coil and different distributor incase the Pertronix is bad or installed wrong. I literly try everything I can think of well into tonight. So I am putting the Pertronix distributor back in and I bump the starter and watch the rotor turn counter clockwise. I thing I am seeing things and the bump it again and watch it turn counter clockwise for sure. I literly screamed out loud. So I set the timing and correct the wires in the right order and it fires in less than 1/2 a revolution and sits there and purrs at idle. I can't believe how much of a headache its been for such a simple fix.
      Thomasville, NC
      I bought a Bronco CHEAP because someone did the exact same thing.....redid the wires & off I went.
      Damn nice car, BTW.
      1966 Pontiac Catalina Ventura
      389/TH400, Wide-Track Darksider
      Bars, springs, disc brakes, etc.
      1962 Falcon 2-dr
      "just getting started"
      Aug 2008
      Pgh, PA
      Man, you have no idea how much I laughed when I read this. Not because of anything dumb you did, but becuase I know EXACTLY what you went through.
      About 30 years ago I was transplanting an Olds 400 and Muncie 4spd out of a 69 442 (that was wrecked) into my 68 442 with a very tired 400 and auto tranny. I had always been a chevy guy, and so were my friends who were helping. After getting everything in, I could get the motor to fire once or twice, but then it would backfire and buck, and quit. I went through the exact same process until I also discovered the reverse firing order! Swapped the plug wire positions, and presto.
      I will never forget that experience.
      Sep 2008
      Elkhart, Indiana
      I know how you feel Richard, I pretty much did the same thing. I had a friend help me fire my car for the first time and all he had ever worked on were chevy motors. It took us a few hours to figure out that he had iwred it wrong.
      Stephan
      1967 Oldsmobile Cutlass
      468 BB Olds
      Future plans dual throttle-body injection
      Pro-touring suspension
      Nice stock looking interior
      Dallas TX
      The end is near.............
      Well my punch out list is down to just a few items. I finally get to drive it in the next day or two. I have forced myself from starting to drive it because I would not want to go back and finish some details I have been working on. Finally time to reap some rewards of my labor and way too much $$ spent.
      Here is the exhaust I had put on last week.
      Aug 2008
      Pgh, PA
      Now I'm jealous. I'm nowhere near as close to driving!
      Dallas TX
      What do you mean? Its in paint right....I see guys on TV have them ready to drive the next day out of the booth. If they can do it in a day it should only take you 2-3 days right.
      Aug 2008
      Pgh, PA
      Yeah, well, Chip was stuck late on the set so we're behind schedule....
      Seriously, we had a minor set-back. The right rear quarter is going to need to be worked on a little, and then repainted. :(
      Sweet !
      Houston,TX
      Congrats on getting it back on the road man, how are you liking the TKO so far?
      71' Nova - LY6, T56
      Dallas TX
      Quote Originally Posted by NvrDun71 View Post
      Great for up and down the trailer and the whole block it's been driven.
      I hope to have some real feedback by the weekend.
      dayton, oh
      Chevy guys. :bsjerk:
      dave.t
      74 Javelin AMX - stocker
