    Page 5 of 13 FirstFirst 1 2 3 4 5 6 7 8 9 10 ... LastLast
    Results 81 to 100 of 242
    1. #81
      Dallas TX
      Quote Originally Posted by wmhjr
      Keep up the pics. It's funny - I'm working on a '66 GTO/Lemans Restomod right now and am doing some of the same stuff. I went with the SPC adjustable front UCAs and the SPC ProSeries coils all around. Currie Currectrac billet adjustable upper rears and the Currie Billet lower rears. Yours look different, so I'm guessing you got them prior to Currie releasing the newer version. I'm anxious to see how you like your suspension as you just might get done before I do. Mine won't be ready to drive until around June probably.
      BTW, don't know if you knew this but you can buy new cage nuts complete.
      Very cool. I don't know if you saw it or not but when you posted in the 30K thread about your car I said it sounds like you are building my Pontiac twin. (I was really looking for a 64-67 Pontiac when I bought the Olds) You and I must have very similar taste and ideas.
      Thanks for the tip on the cages I knew they are made but sisnce this one was not rusty I desided to to wait for a replacement.
    2. #82
      Aug 2008
      Pgh, PA
      Quote Originally Posted by gearheads78
      Yeah, very similar. You're going a little further with the brakes and wheels. I'm sticking with 11" Ford Drum brakes in the back - discs in the front. However, I might need to go to a Hydrotech booster in the front due to valve cover clearance - don't know yet. Engine will be stroked, forged crank 4 bolt hydro roller approaching 600hp and probably a bit better than 600tq. I'm using stainless for as much of the hw as I can.
      Working with Mark at SC&C for the suspension stuff has been pretty cool, huh? Oh, I also got the wrong center link. Got it right the 2nd time around.
    3. #83
      Dallas TX
      And she inches closer
      A little was done today got the dash, 4 speed pedals, and heater box together on the inside and the firewall mostly together on the outside. Also got the gas tank back in place. I then finished assembing the floor shift column I am converting to. Working with all the new painted areas today was pretty nerve racking. Not near a forgiving as the powder coating. Made a nick here and there but not anything anyone will even notice.
      The last thing I was working on tonight was driveline angles. Ended up having to raise the back of the transmission 1/2" to get a 2.25* front and 2.5* rear working angle. Thanks go out to Andrew with the GTO for posting this link and talking about this in his build. It helped me figure it out quicky.
      http://<br /> <a href="http://www.v...Angles.htm</a>
      I wanted to make sure that was done before I get the body back on. The last thing I need to raise the floor to clear the trans and then not have enough clearance to get the driveline right.
    4. #84
      Dallas TX
      Don't know if it was the scatter shield or the aftermarket shift arm or combo of both but there was not near enough clearance for the shift fork to move back. Had to spend a few minutes with a die grinder.
      I opened the new body mounts for the first time today. One mount on each side would not fit. The hole in the frame was a lot smaller on that one mount. I don't know if if it was a misboxed product but I did not want to wait a week to get the right part. My first thought was to trim the frame out to match the other holes but I did not want to cut the powder coating. I then decided to cut the rubber down. I think I cam up with a pretty cleaver way to do it after brain storming a little while.
      I first measured the size of the old original bushing. I then found a 3/8 fender washer that was close to the size but still apox .075 big. I took a long 3/8 bolt and nut and tightened it all together. I then chucked it up in the drill press. With a file I cut the washer down to the exact size I wanted to cut the rubber to. Now I had a perfect guide. I took the long 3/8 bolt with my new resized washer and another washer on the back side. I centered the guide washer on the rubber bushing and tighened it snug enough to hold. Chucked up in the drill and carefully used a razor blade to trim the rubber pefectly to the size of the washer. Hear is a cut one next to an uncut.
      I wanted to be really close when setting down the body. So I used two plumb bobs. One front and one in the oppisite rear corner. I little scooting around on the jack and the frame was exactly where I wanted it.
      My plan was to always try to use this factory console I picked up off EBAY last year. I used a hole saw to get the shifter stub though the floor. I then drew and outline of where the console would sit. Well long story short I will not be using the console. Once the minimal cutting was done to clean the transmission I was well outside my outline for the console. I could still make it work but it would require a good bit of modification to the console. I paid way to much for this thing to risk messing it up. Its probably for the best. My daughter likes to walk between the seats from the back to get out of the car. When she stepped on it and broke it I might has had to kill her I just going to put it up for sale so someone with a original car can use it.
      Here is the bare minimum cutting it took to clear the Tremec TKO600. If you do not have your transmisson shimmed up 1/2" in back like mine you you may not have to cut as much. I plan on cleaning up the cuts and start covering it up Sunday
      Don't think I need any expanation here
      -Richard
    5. #85
      Too bad about not being able to use the console. It still must feel good having the body back on the frame. Looking good !
    6. #86
      Dallas TX
      Got a little done today. Once I finish the floor its time to put it all together to drive.
      Cleaned up next to the hole with scotch brite disc
      Used a hammer and dolly to bend the flange arond the hole.
      Made it out of poster board first.
      Don't be jelous of my high dollar metal forming equipment.
      First piece in.
      Starting to take shape. Still need to make the back piece and finish welding it all up.
    7. #87
      Oct 2008
      texas
      Real nice ride you're building, What wheels are those? I love them. I saw this project over at ROP and wanted to comment but for some reason I can't get registered. Maybe because I put a LS1 in a 1965 cutlass. The purest are mad I guess. When you get done bring it out to the country, we'll line them up. I just gotta know if I should regret selling that 455 and going ls1 instead.
    8. #88
      Dallas TX
      Quote Originally Posted by rockytopper
      thanks man.....As for ROP is a pain in the ass to get registered anyway but you might me right. They black balled you for the LS swap .
      The wheels are Intro V-rods but the paint detail is my work. They come all polished.
      I dought you will regret going with an LS motor. They make stupid power for effort spent. I built a very mild combo in a 98 TA and had it running 7.1's . It was so easy making that car quick it was almost like cheating. My next project will be LS powered. Probably a 3rd gen F-body street / stip car with a bottle fed 408. Bottom 6's and still street worthy sounds good.
    9. #89
      Dallas TX
      Its been a little while since I worked on it. I've had 30 min here and there but today I spent most of the day. Finshed welding up the tunnel, dressed the welds, cut the hole, smoothed a little mud on the seams, and sprayed it in bare metal epoxy.
      Now I just need to spray it in black and the tunnel is done. Next up buff and clean of the body and its ready to back on bolt on.
    10. #90
      Sweet, keep pluging at it !
    11. #91
      Dublin, CA
      Great job on the hump, and the frame looks really good. Get the interior back in and do some driving!
      Brent
      1971 Camaro, LT1, 4L60E
    12. #92
      Oct 2008
      Rear discs
      This is an awesome thread! Very informative. I am working on a 1966 Lemans and I'm currently doing the LS1 rear brake swap. I came to the same conclusion for spacing out the backing plate, and having axle retainer spacers machined, but I am concerned with the axle length. Im afraid when I bolt on the rotors, they may bind against the parking brake shoes. Has this been an issue? Is there enough length on the axles to add all of the spacers, including the 1/2" thick backing plates?
      Thanks for all the pics, I don't think I could be doing this without your experience.
    13. #93
      Dallas TX
      Quote Originally Posted by Lorretta
      Nice ride. Where in TX are you? I am a Pontiac Abody fan too. In fact part of the reason I have not worked on this in a while is I picked up a 64 Lemans project two weeks ago. Thanks for props on my build.
      As for the brakes I was wondering the same thing when I started this. I measured a freinds 01 Camaro and the axle face is close enough to the same it all works.
      -Richard
    14. #94
      Dallas TX
      Quote Originally Posted by Motown 454
      Thanks just got some semi-gloss black on it. Inside now killing time waiting for 2nd coat.
    15. #95
      Dallas TX
      Quote Originally Posted by barno68
      Thanks its almost a shame to put the old body one new frame. I want to drive it BAD!!!
    16. #96
      Dallas TX
      I can't do it....I just can't put the body on with out making the paint and trim as best as I possibly can. After painting the tunnel I stripped all the trim off the body. Going to do everything I can to make the original paint look good/ then I will detail all the trim. Just digging a little deeper.
    17. #97
      You know what they say if your going to jump in it might as well be the deep end. Looks great
    18. #98
      Dallas TX
      After seeing you car I don't think its possible to go deeper LOL
      Going to feel much better now. Got a good bit done to the car today. Started by washing it down good and masking everything off to keep from slinging compound everywhere. I sanded it all with 2000 just enough to smooth things out a bit. The factory paint still has a good bit of peel but I did not want to risk cutting through so I was very conservtive in my sanding. I then washed it again to get the sanding sludge off. Finally I buffed it all with a wool pad and 3M Perfect It II compund and washed it again. I still need to polish with a foam pad to remove the swirls. Its still not going to be anywhere near as nice as new paint but its at least 70% better than it was.
      Everyone needs a color sanding assistant.
      All sanded...no turning back now
      And buffed
    19. #99
      Dublin, CA
      That looks fantastic for still being the factory paint. Is it possible to clear the old urethane?
      Brent
    20. #100
      Dallas TX
      Its laquer but its not in good enough shape to save premantently. All the top surfaces have tiny checks and crazing all over. Just trying to get it to look the best I can for now. In a year or so it will get a full strip and paint it deserves.
