    Page 32 of 36 FirstFirst ... 22 27 28 29 30 31 32 33 34 35 36 LastLast
    Results 621 to 640 of 763
      Under Lake Michigan
      After I had made my previous posts, I realized that I never posted a picture of the MC as it was finally installed. You can see the new 5/16" rear line along with the adapter that was needed. The rear port for the front brakes worked as is.
      I hope this is ok to post to your build thread. Wasn't sure where to put it...
      I'm contemplating swapping my vac boosted MC to this non boosted MC.
      I've been doing some autocross events and I want to make the brakes on my 79 TA more reactive to my inputs. Front brakes were upgraded up front to LS1 calipers and 13" rotors. I thought this would help the brakes to work sooner (or be more reactive) with more piston area but it seems roughly the same. Maybe it has more braking ability but the same reaction. They look much nicer than the factory brakes behind the wheel but looks aren't everything.
      I don't like the slow reaction of hitting the pedal when approaching a corner and it takes a bit before I get the brakes to react. It seems like the booster is slowing my input down if that seems logical. Plus the factory MC is 1.125" bore.
      The car still has the factory drums in the rear for now. I have most of the parts to swap in the LS1 12" rear disc minus some new rotors and pads.
      What do you think? Was this a worthwhile swap? Or is there something else that I may be overlooking?
      Mike
      15 Camaro 2SS 1LE summer ride
      00 Yukon work ride - parts hauler
      69 Camaro LS Turbo - project car
      If I can't toot my own horn, who will?
      Got a nice 4 page feature story in the current (February 2014) issue of GM High Performance and a action shot from LS Fest in the current (February 2014) issue of Popular Hotrodding. Woot!!!
      Nov 2012
      Sacramento, CA
      Nice !!!!
      Sep 2007
      Thehoodstock,GA
      Andrew, always loved your build thread.
      I hope you continue to update.
      MarkK
      May 2013
      Quote Originally Posted by ETexGTO View Post
      That picture was actually taken at LS Fest in 2011. I don't believe PHR has coverage for the 2013 LS Fest up on their website yet.
      Thanks GM High-Tech Performance!!!
      http://www.gmhightechperformance.com..._gto_ls3_swap/
      There have been various discussion on several forums that I frequent regarding driveline vibrations, angles, etc...
      In one of the posts, I made the comment that just about every modern, rear wheel drive, performance car uses CV joints for the driveshaft. We spent all kinds of stupid money to buy the latest engine, transmission, and suspension parts, but when it comes to our driveline components, we still use u-joints that date back to the 19th century. I have used a CV driveshaft with great success, but the optimal solution would be to use a driveshaft that uses a CV joint at both the transmission end and at the pinion. So I called Frank at The Driveshaft Shop to discuss this further and after telling him all this he starts to laugh. Then he proceeds to tell me how he just made a batch of pinion yokes for the Ford 9" and the Chevy 12 bolt rear ends that will accommodate a 108mm (Porsche 930 style) CV joint. He sent me the picture below:
      That particular yoke is for the Ford 9" rear. What this means is that if someone wants the ultimate solution for a driveshaft, this is it. Using CVs at both ends of the driveshaft means that driveline angles become largely irrelevant. The CVs can accommodate up to 9 degrees of articulation and the front and rear angles operating don't have to match, be opposite, or be as small as possible.
      Dec 2008
      Detroit
      Nice piece! Are these readily available for sale?
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
      Quote Originally Posted by csouth View Post
      Frank said that he has them in stock.
      New York, NY
      Andrew - can you explain why you would need a CV joint at the pinion end of the driveshaft? Of course a CV joint at the transmission joint is useful, because packaging constraints sometimes force front u-joint operating angles to be larger than 3 degrees. However, I can't think of any rear suspension setups where pinion angle isn't adjustable. I understand CV joints are still stronger than 1350 u-joints, but if a 1350 is sufficient and you can get rear operating angle to less than 1 degree, why would you spend the extra money for a rear CV joint?
      Quote Originally Posted by jerome View Post
      In a static configuration (car at rest) you're absolutely correct. However, we know that cars are driven and when forces are applied to the rear axle the pinion will have a tendency to rise. How much or how little depends on the suspension design and the bushing material, but the pinion can move a surprising amount. Also, under various conditions it can move a lot or adjust a little, based on how much power is being applied. So while it is fine to set-up the pinion angle so that the rear u-joint working angle is less than 1 degree (this is what is recommended with a from CV joint) it is difficult to dial that angle in under a wide variety of conditions. With the CV at the pinion, the amount of pinion climb become largely irrelevant.
      May 2010
      kitchener,Ontario,Canada
      I search the website and nothing was a there, I emailed the driveshaft shop and was promptly replied to. The pinion yoke is in stock and in the case of the 12 bolt rearend its price is 199.99$ probably safe to assume that the ford 9" would be a similar price. I also asked what a very rough price would be for a gm A body carbon fiber driveshaft with cv joints at each end. If you want to know what the price is pm me. As I don't want anyone on here calling up the driveshaft shop and trying to hold them to a price that was intended for me and I did state a very rough price. It's not that I don't trust anyone but I think it's just the best way to prevent problems.
      Regardless I will be taking a page from Andrews gto and going the same route for my chevelle
      Ryan Austin
      Batesville, IN
      Very Cool!
      Brandon Wiedeman
      1972 Suburban
      Wiedo's
      May 2007
      Mooresville, Indiana
      Somehow I've missed this thread for a long time. Now one of these days I will go through the whole thing, but for now, I will just keep up with the new things!
      May 2010
      Don't suppose you know if the 12 bolt design is a high dollar item do you?
      Ryan Austin
      Ryan Austin
      Ryan,
      Frank and I didn't discuss cost, but I would imagine that it is comparable to other billet yokes on the market.
      Atlanta GA
      oh shoot, Andrew putting in work!
      Jan 2007
      That CV pinion yoke is super nice!!!
      WWW.SPEEDINC.COM 1957 Eldorado Brougham.......in progress
      Quote Originally Posted by INTMD8 View Post
      I wish Frank had it available when I got my driveshaft made.
