    Page 4 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 ... LastLast
    Results 61 to 80 of 201
    1. #61
      Oct 2005
      Jasper,IN
      No major mods to the stock subframe. A little trimming around the coil spring pocket to allow room for the Shockwaves. Stock width axle, we did not have to move the lower bars in or make custom offset bar either. Jason took some good images of tire clearance......
    2. #62
      Quote Originally Posted by darren@ridetech
      it looks great, most guys run 12 inch wide rear rims which will not clear the factory style mount you use, an 11 inch rim like you used or even probaly a 11.5 will clear with correct back spacing.
      most tire makers suggest 11.5 to 12.5 for 335 tires.
    3. #63
      Phoenix, AZ
      You guys build cars like we do in just days, I love it
      Chris Fesler
    4. #64
      jasper IN
      i found 1 of them, i will look for some others i took the other day.
      Jason Brady
      www.ridetech.com 812-482-2932
      The Guy who invented the first wheel was an idiot. The guy who invented the other three was a genius.
    5. #65
      jasper IN
      few more pictures.........
      Jason Brady
    6. #66
      Awsome work
      I just looked through this thread that car is awsome. This is the first time I've seen it. I say stripes lke thats a good idea. Keep the updates comming .
    7. #67
      Socal, Ca
      What kind of gas tank are you going to run?
    8. #68
      jasper IN
      we used a ricks hot rod tank. its under the rear cover.
      Jason Brady
    9. #69
      Jan 2007
      CT
      very cool rear diffuser....is that an "one off" or was it purchased through a vendor channel....(if so do you have a name)
      Thanks Nick
    10. #70
      jasper IN
      it's a custom, we made it.
      Jason Brady
    11. #71
      Mountain View, CA
      Quote Originally Posted by jb@ridetech
      That pretty much kicks ass!
      What size is the tank?
      Custom from Ricks or standard product?
      Baffled?
      Is there a cell liner in it?
      True T.
      My blog
    12. #72
      jasper IN
      well we are getting close now, it now runs and we are finishing up some small details, lights, exhaust etc....
      Jason Brady
    13. #73
      St. Augustine, FL
      Maby it's already been covered. But why no subframe connectors? I know you guys tend to drive cars hard.
      Andrew Petty
    14. #74
      jasper IN
      Quote Originally Posted by 69Nova
      I doubt we will use a sub-frame connector, but there are some other parts in the works........ I'll show you as soon as we get it going.
      Jason Brady
    15. #75
      jasper IN
      Quote Originally Posted by Damn True
      Baffled?
      • These tanks are designed to retro fit a Fuel injected motor in most popular Chevrolet, Ford, and Mopar Muscle Cars.
      • System Includes an installed fuel pump, ready to run.
      • Fuel Pump Specs: Supports up to 450 HP. @ 13.5 volts pump is rated for 51 PSI and will flow 41GPH. (155.2 LPH)
      • Replacement AC Delco fuel pumps are readily available at your local GM dealer, GM part number EP381.
      • Pump sits in separate chamber within the tank to eliminate starvation during low tank levels.
      • All tanks are baffled to control fuel tank slosh.
      • Works just like an O.E. in tank system and features -6 A.N. supply and -6 A.N. Return.
      • Power is transferred to the pump via the electrical terminals located at the top of the injection provision.
      • In-tank pump for fuel injection that works like an O.E. System which means added reliability. All Injected tanks have a -6 Supply and -6 Return.
      • Note: Any interruption in fuel flow will cause an injected motor to stall. With the Rick’s Hot Rod Shop Fuel Pump Chamber this will eliminate any interruption in flow.
      Our tank has an upgraded pump. I found this on ricks website. thanks Jason
      Jason Brady
    16. #76
      Oct 2005
      Jasper,IN
      I think that it is around 16 gallons. It is a standard tank that they produce specifically for Camaro's with Minitubs, the corners are cut off to allow exhaust clearance.
    17. #77
      Socal, Ca
      Video?
    18. #78
      I'm surprised that there's no sub frame connectors?
    19. #79
      Oct 2005
      Jasper,IN
      We are installing a roll cage, which will help reduce body twist.
    20. #80
      La La Land, CA
      Cool ride. I really like the rear treatment, very unique.
      What did you guys do to improve the factory front suspension?
      Tyler
