    Page 2 of 2 FirstFirst 1 2
    Results 21 to 40 of 40
    1. #21
      Aug 2005
      Hamilton, NJ
      The LH8 pan looks awful low, like it would be below the xmbr. Hmm.
      None of the BHP stuff looks high quality.
      Scott from NJ.
      Vent Windows Forever! ...
    2. #22
      This guy is over on LS1 Tech. Hes not too far from me, but I can use the crossmember from several venders thats made for the 700r4. I have a 63 Biscayne ( Impala ) Wagon and have been thinking of doing the LSx swap.
      I am not sure if the 4l80e will work with the same crossmember though.
    3. #23
      May 2000
      How stout does a trans crossmember need to be? The motor mounts are responsible for stopping engine torque rotation.
    4. #24
      Jul 2001
      Detroit, Michigan
      Good point.
      1968 Pro-Touring Camaro LS1
      Project: Next Year
      - Start date; June '01
    5. #25
      Lafayette, La
      Crossmember needs some better welding, but thats an easy fix
    6. #26
      Nov 2007
      Cleveland, Tennessee
      Quote Originally Posted by MarkM66
      Your right.
      Some of Phil's (BRP) pics don't show what the final product looks like. I know he takes pics during the mockups, and never updates the website, or ebay ads when the final part is released.
      Scott
      I got 99 problems, but a stock turbo Nissan GT-R ain't one.
    7. #27
      Hi this is Phil Brewer from BRP Hot Rods this is my kit that’s being discussed. Just to clarify a couple things like Scott said those are mock up photos showing fitment in cars not the finished product. The photo that’s got you all buzzing is of a cross member that is just tack welded for mock up purposes. These cross members are tucked up close to the body so you can actually clear big tube exhaust systems, I have had these cross members go in cars with over 650HP and never had a problem. All kits are made in the USA at my shop and I have sent out hundreds of these cross members and never had an issue about strength and all motor mounts have a 5 year 50,000 no questions asked warranty. BRP helped start the LS conversions with the 1969 Year One Convertible Camaro that got the cover of Hot Rod BRP builds a quality product with a warranty at a good price with Year One being our biggest distributor. How many magazine cars do the other guys have? The other thing that is not taken into consideration is how much hidden cost to the other kits have? BRP kits are made to fit with the least modifications as possible so that stock accessories fit without having to pay thousands for aftermarket set ups and time consuming frame and trans tunnel mods even with a T-56. Every kit I sell is built off a real car I sell no generic kits so it fits the first time.
      The LH8 oil pan looks similar to the truck pan which throws off your but its 2in shorter then it. The link shows it being compared to an F-body oil pan which was to most common LS conversion oil pan. This is a GM pan so it’s the highest quality and you can get and you will not find a LS conversion oil pan close to this price. For 249.99 with any kit you get all new gasket, all new hardware, Pick up tube and wind age tray. Plus it keeps the oil filter on the block so no oil filter relocation kit like most aftermarket pans. To just modify a stock F-body pan it cost over $250 from the other guys not including the Core pan and any gaskets and you get an ugly hacked up pan with less capacity. This pan makes LS conversions a whole lot easier. http://brphotrods.com/Oil%20pan.html
      Guys im making these kits so that anyone can throw a LS engine in there car. I have polyurethane bushing and solid mount motor mounts as optional equipment. I can even over engineer the cross member if you want an over the top set up. Here are some additional photos of a finished cross member for that’s about to go out.
      If you have any questions just ask I got kits for most GMs from 1955-1996. I just signed up for this site and I will make some post about the various kits I sell this week. I can posy any pictures of any kit I sell during mock up or finished product
      I also have some trick adapter kits for the 98-02 Camaro brakes and the first ever bolt in shock relocation kit for the 1967-1981 F-body and 1968-72 X-body
      Also im looking for these cars for mock up if any one is close to GA
      1965- 1996 B-body impala
      Phil Brewer
      [email protected]
      www.BRPHotRods.com
      770-751-0687
    8. #28
      California
      That thing still looks like it's at least 2" lower than an F body pan.
      Matt
    9. #29
      Nov 2007
      Quote Originally Posted by DarkoNova
      Matt
      It is. Most swap, and f-body pans are 5-5.5" deep. The alpha pan is 7", but almost all sbc pans are also 7-7.5" deep. The truck pan where I messured is about 8.25". I have not used this pan or mount setup yet, so I can't really provide any feedback.
      Yes there more over engineered, costly, and sometimes more eye appealing swap kits, and front subframes available, but I think BRP's goal is to provide a cost efficient way for most garage hot rodders to swap LSx series engines into their older cars. I have used BRP mounts/crossmembers, and brake kits, front subframes, and inboard shock relocation kits on over 10 cars that I have installed LSx swaps into. I have never had a problem. Even when I had clearance problems (4L80e, and I moved the engine further back) I marked up the trans crossmember where it hit, and included pics of where I was trying to install it, and sent it back to BRP. They sent me a new trans crossmember built to my specs no charge. Not trying to be a cheerleader, but with customer service like that its hard not to be.
      Scott
    10. #30
      California
      Quote Originally Posted by deviousz28
      Scott
      I don't doubt that they build nice stuff, I just don't see how they can expect someone to use a pan that deep. Granted, I haven't seen a muscle car with an LS1 in it up close, so I don't know how a stock F-body pan would fit, but I'd imagine that an extra 2" couldn't be a good thing.
      Matt
    11. #31
      St. Pete FL
      subscribing
      HELP!!!
    12. #32
      Apr 2007
      Houston area in Texas
      Did anyone figure out which headers can be used with this kit?
      As for the kit itself, this is the type I am looking for. I don't want to break the bank doing a ls1 swap. I also don't want to mix and match parts, hoping things will fit.
      http://i174.photobucket.com/albums/w...k/IMG_0629.jpg
      1969 Conv. SS-350 4sp
      1969 Conv. 327 4sp
    13. #33
      Stainless works built its headers off of my LS conversion and most ls conversions will fit on the first gen I have had my customers install just about every brand going.
      These kits will work with the aftermarket LS conversion pans that have the rear sump so if your worried about clearance just run one of these style pans I know Moroso and auto Kraft make some great looking products. The LH8 pan is higher up then a small block pan and sits about ½ up then the stock location of a traditional small block.
      Also for the guys who want the high performance kits BRP developed a new great looking poly kit using energy suspensions bushings that is simply the best on the market. This is the prototype version for the first gen the final version will be fully cad coated along with the frame bracket and cross member I will have productions version ready for every kit in 2 weeks. The new motor mounts come with a lifetime warranty and are rebuild able units for only $100 over the cost of the base conversion kit. More photos and details very soon
      patent pending on this new style conversion kit
      Just call me if there is any questions at
      770-751-0687
      Im becoming a sponsor on this site as well and will be offering a giveaway contest very soon to the members of the forum.
      Phil
    14. #34
      St. Pete FL
      Phil,
      Good stuff as usual! I need to call you later this week.
      HELP!!!
    15. #35
      Huntington Beach, CA
      Cool
    16. #36
      Apr 2007
      Very nice info.. I hope to find a lsx/t56 combo for a reasonalbe price so I can start on the path to reliability.
      1969 Conv. 327 4sp
    17. #37
      Dec 2007
      Tampa, FL
      Hey I am in Florida but will drive my 1980 z-28 up to see you if you need a mock up car... I like dealing with companies here in the south myself. More integrity IMO
      Nate
      1980 Camaro Z28
      2006 Cobalt LS (Warranty almost gone time for forced induction)
      www.fquick.com/GTOnate
    18. #38
      Nate, I already that kit mocked up and ready to go, just call me ill be glad to help you out and make sure you get everything you need and answer any questions you might have. I have almost every car I sell a kit for on my property so that when I sell I kit I know its going to fit . I can send some images on the 2nd gen kit if you would like I plan to post here with clearance shots and info about each kit as soon as I get everything ready for production.
      I have kits for the following versions in ether base form or high performance version. Each kit is built off a real car so it fits unlike the generic kits that cause a whole lot of unnecessary extra work. The high end line will be ready for all models in about 2 weeks
      1955-1957 Tri five and it clears stock steering perfectly
      1958-1964 B Body
      1962-1967 Chevy 2 nova
      1964-1972 A body forconvertibles el Caminos & hard tops(each have a unique cross member)
      1967-1969 F-Body and 1968-1972 X-body
      1970-1981 F-body
      1963-1981 Corvette (this is a fixed motor mount that uses stock frame mount)
      1978-1981 G-Body
      1982-1988 G-Body
      1955-1987 GM truck
      I am looking for these cars to mock up in GA and and can cut a good deal if any one is near Atlanta with these cars
      1965-1996 B Body impala
      1973-1977 A body
      Any other suggestions???
      Phil
    19. #39
      Jul 2008
      Camp Pendleton, Ca
      I was planning on fabing my own mounts but I think I might buy these to reduce down time
    20. #40
      Nov 2004
      Dallas Texas
      Quote Originally Posted by jkwalkercchs
      that crossmember doesnt look to rigid to me but idk it my be real thick and not welded by chinease laborers
      my BRP trans crosmembers I've had look nice (had an auto and then BRP was kind enough to swap me out for 6 speed) quality is good and they are GREAT to deal with!!
      also in response to this:
      Keep in mond that the LSX are deep skirted blocks I.E. the pan starts out lower than typical SBC that pan mounts almost flush with the crank centerline.
      now if I ever get mine back from my bodyman.......
      Rich
      69 Trans Am "TireBird"
      M6 / LS6 minitubbed DSE Sub
      C5 frt LS1 rear disc brakes
      https://www.pro-touring.com/forum/showthread.php?t=14992
      69 R/S Z28 302
      15 Camaro ZL1
      90 Formula next project
