    Results 1 to 20 of 40
      Springfield, Mo.
      WOW... LS1 conversions keep getting cheaper!
      Has anyone seen / used this kit? I found it while messing around on e-bay and was shocked at the price!! I spent more on my oil pan than this entire kit costs!!
      http://cgi.ebay.com/ebaymotors/67-68...3756.m20.l1116
      Thoughts
      1967 Camaro - Done!
      1968 Camaro - Underway
      if i am reading that right the oil pan is seperate
      Flo-rida
      Yea the oil pan is seperate.
      1993 Camaro Z28
      2001 Camaro Z28
      1969 Camaro
      Apr 2004
      Cedar Rapids, IA
      I think your right. That is a little deceptive.
      "The LH8 Oil Pan is sold separately in out eBay store for 249.99 for the complete oil pan kit"
      Eastern Virginia
      Last line of the auction says this:
      Maybe it was added since you saw it Wayne.
      Scot
      86 Monte SS
      Los Angeles, CA
      Does that transmission cross-member look a little sketchy to anyone else?
      Jul 2001
      Detroit, Michigan
      It's still not a bad deal. My conversion mounts and crossmember came from S&P and my oil pan came from AutoKraft. Total cost came to $750. That kit right there will cost you $625. Not a bad savings. However...You'll need to ask them what headers can be used.
      In regards to the crossmember....I think it looks better than the S&P. The way the S&P is configured it's right in the path of the exhaust. That one looks like it tucks out of the way.
      1968 Pro-Touring Camaro LS1
      Project: Next Year
      - Start date; June '01
      Jun 2006
      NW burbs IL
      But it looks flimsy. ( pinched ends? )
      Matt
      Jul 2002
      Mesquite, TX
      I'm sorry, but my initial thought when looking at that crossmember was that somewhere, some kid was missing his swingset.
      I'm sure it's better made than that, but it's still the initial thought I had.
      Windham, NH
      Quote Originally Posted by derekf
      That is so funny, I am no structural engineer, but I had the SAME EXACT thought!
      Phil
      Build site: www.73camarobuild.com
      Business: www.classiccarblasting.com
      Like us on Facebook!
      Cape Cod Mass.
      Is it me or does that weld not look too good ??
      NOW WHAT??? lol
      Alabama
      I think it still looks expensive. Half the parts in the picture aren't part of the $375. So all you are really getting is the motor mounts and a crossmember that looks like it was bent out of exhaust pipe. Also since there doesn't appear to be any setback in the trans crossmember, that engine must be sitting pretty far foward. You could probably do Tylers crossmember and make your own mounting plates for just as cheap, and it would look a lot better.
      Aug 2001
      Isn't a big block 69 Camaro T400 crossmember also a pinched end ?
      Jun 2006
      NW burbs IL
      Quote Originally Posted by Charley Lillard
      Yes, but it looks like the GM is a much larger tube. ( its tube is wide enough to pick up both bolt holes when flattened )
      Matt
      Jul 2001
      Detroit, Michigan
      I think the pinched ends are what's throwing you guys off. I doubt it's made out of exhaust pipe. We're going to need to see some better pictures of it.
      Project: Next Year
      Springfield, Mo.
      well nevermind then, I thought it was a hell of a deal b/c of the oil pan, i didnt realize it wasnt a part of the package.... thats what i get for skimming over it too quickly and then posting!!
      1967 Camaro - Done!
      Red Deer, Alberta, Canada
      the BRP kit I first started with has the exact same style tranny crossmember. it was of the same thickness of the stock style if not thicker. From my memory the pipe was 1/8" to 3/16" wall. Plenty thick. Double up the ends and your looking at 3/8"s thick. Pretty gnarly.
      Matt
      Instagram: Cst_koon
      OC CA
      Quote Originally Posted by protour_chevelle
      X2 on the quality. Pretty beefy piece.
      I bought this stuff 3 years ago and paid 460.00 w/ shipping for the crossmember and m/mounts. definitely getting cheaper with prices coming down on motors too.
      Mark
      LS1- T56
      under construction
      "Political Correctness is a doctrine, fostered by a delusional, illogical minority and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
      May 2002
      Northern California
      Quote Originally Posted by TA219
      its not a bad kit for the price. We have no idea of the tubing thickness but if you ever worked with swedged end tubing it is quite strong and this should suffice for its usage. Look at what the 4th gen Camaros use for x members.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Feb 2008
      that crossmember doesnt look to rigid to me but idk it my be real thick and not welded by chinease laborers
