    Results 1 to 13 of 13
    Thread: Efi Help ! ! !
      Feb 2008
      Cookeville, TN
      Efi Help ! ! !
      I am doing an S10 v8 swap, and am having the hardest time ever deciding on an E.F.I. setup. I need YOUR suggestions. Please take into account that I need it to be a relatively easy to install on a 355 Chevy Small Block engine with a relatively thumpy Lunati. I will get specs on it shortly. (I don't know right off hand) I also need it to be a realtively inexpensive process. Maybe, something I can find at a pull-a-part or common junk yard. I was looking towards vortech heads, but I would eventually like to purchase a nice set of aluminum heads to open myself to more flow, and that is what I would like it to work on. If I need to give you anymore info as far as specs or technical things, please feel free to ask and I will do my best to get it. Like I said, I am OBLIVIOUS to EFI, but intrigued and would like to take a swing at it. Let me know what you have in mind.
      ALSO: The truck is gutted so it will be really easy to adapt harnesses in. Keep this in mind if you have an idea that requires some wiring and stuff. Thanks Y'all
      Yeah . . . It's an S10.
