    Results 1 to 12 of 12
      Hackettstown, NJ
      pilot bearing source
      looking for a needle bearing pilot bearing with the follwing dimensions:
      Bore=0.5906" Outer Diameter=1.378" ...what company has one. its for a pontiac engine. all I can find is ball bearing ones.
      DORMAN Part # 14665 More Info {Inside Diameter 0.592" Outside Diameter 1.381" .363"}
      www.rockauto.com
      Scratch that...I misread your post. The above is a bushing, which I personally would prefer over a roller bearing.
      Hackettstown, NJ
      Quote Originally Posted by andrewb70
      why so. this is opposite of what I have heard
      bushing - bad
      bearing - good
      Quote Originally Posted by Takid455
      bushing - bad
      bearing - good
      The bushing has no moving parts. It is also much more tolerant to slight misalignments. A bushing is also soft and will not bugger up your input shaft in case of failure. Don't over think this. Get a 2 dollar bushing, put a dab of high temp grease on it and forget about it. That's just my opinion.
      When I got my TKO, they insisted that the "needle bearing" style pilot bearing was an absolute must.
      Quote Originally Posted by Tom 72RS/SS
      Who is "they?" I would love to know the reasoning behind their insistance.
      Clinton, MS
      Go with the bushing! I actually ruined a needle bearing trying to install my richmond, the bushing is more forgiving.
      Boonville, Missouri
      If you insist on roller pilot bearing try:
      BCA 202-FF .5906 Bore x 1.378 O.D. Timkin can reference this part number as well. Cost - $8.83
      Tony Edler
      Illumin8s
      '73 Dodge Challenger
      It was Classic Chevy 5 Speed that claims since the TKO is more precise than the Muncies and Saginaws, a needle bearing style would perform better.
      Personally, I don't know either way but one came in the kit so I put it in and all works as it should.
      Oct 2006
      Phoenix, AZ
      Bumping this one to the top...
      Is there any reason why I should be searching for a roller pilot bearing vs. the bushing type for use with a TKO600?
      Also, can anyone verify that the 400 SB takes the same pilot bearing as all other small blocks? I had a dumb parts guy that's attempting to overcomplicate the issue....
      Jeff K.
      69 Camaro SS, 406 SBC, TKO600, 9" w/3.73 tru-trac, Speedtech Arms, AFX Spindles, Lee 670 Box, Baer GT front, C5Z rear. Hyperco Leafs w/ Fays2 Watts Link + Varishocks.
      Rockford, MN
      If you have an aftermarket crank, chances are a bearing may be too loose. It needs to be a slight pressure fit. I tried several bearings and all were too loose, so I went with the bushing. I tapped it a few times around the circumference with a punch to ensure it was tight. I'm running a TKO600.
      1969 Firebird, Black, Parchment Arizen interior, Poncho 383 (4" crank), Kauffman heads, TKO600, Moser 12 bolt, Wilwoods, DSE, Speed Tech, Koni, Hotchkis, GW, 18" TTI's, VA Gen IV, etc.
      If you install a TKO, it is a must that you use a needle roller bearing and not a bushing. Tremec requires it as does CC5S and Keisler Engineering. It will void the warranty if you do not use one.
      CC5S is correct, the tolerances on the TKO are much tighter than a muncie or A833 or T10. Therefore a roller bearing must be used. If you grab the input shaft of a muncie, A833 or T10, you can literally move it in, out, up, down etc... because of the "play" in it. You cannot do that with a TKO. It will not move. That is the reason for going with a bearing over a bushing. The bushing will give, the bearing will not. That is also why you MUST perform the bell housing alignment check (runout) when installing a TKO, to ensure the input goes into the crank as straight as possible.
      For the record, the Pontiac and Olds motors use a ball bearing style bearing which is fine for use with a TKO. In fact, that is what we supply in our kits with those motors.
      Richard
      Tech Support
      Keisler Engineering
