    Results 1 to 10 of 10
      Nor Cal
      Control Arm question
      Can someone tell me if different brands of control arms (specifically AirRide Strong Arms vs. SpeedTech) installed on the same front setup will cause the wheel/tire combo to stick out further or tuck in more than with the other brand?
      We ordered my fronts after much research and communication with other 68 Camaro owners and am pretty sure I nailed the width/BS numbers, but apparently the tire sticks waaay out of the fender too far (like an inch at least). I have Strong Arms now but am wondering if using them caused this. Can the difference be as much as an inch??
      I did a search and couldn't find the answer so I posted this.
      thanks!
      1968 Camaro widebody project
      2004 Mustang LS2
      1964 Continental
      2014 Keezer
      May 2002
      Northern California
      Most aftermarket arms are closely based to stock dimentions so they may not.
      Pictures and alignment specs would be a great help.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Nor Cal
      Hmm... we are wondering if the measurements of our custom wheels are off from what we ordered. Measuring today and calling the maker tmrw....
      These parts (control arms, brakes, wheels/tires) were literally just installed on the subframe and body lowered over it for fitment mock-up. Don't have pics yet. No alignment.
      I mean, can 2 diff control arm brands vary as much as an inch+ ??
      2004 Mustang LS2
      1964 Continental
      2014 Keezer
      Aug 2003
      Put a 24" level on the tire and make sure the top of the tire is leaning in (Negatvie camber) Half to one degree would be something around a 1/2". I can almost bet you have possitive caster right now (tire leaning out at the top).
      Orlando, Fl
      Quote Originally Posted by ProdigyCustoms
      I believe Frank meant positive camber here.
      Oct 2005
      Jasper,IN
      The StrongArms are built to factory width. Don't some of the aftermarket disc brake kits push the wheel out a bit?
      Nor Cal
      Quote Originally Posted by darren@ridetech
      We are using Wilwood 13" rotors on front.
      2004 Mustang LS2
      1964 Continental
      2014 Keezer
      Nor Cal
      we feel the wheel maker might have made an error in the dimensions. Probably gonna send back for adjustments.
      What's the maximum amount of shims you guys feel good about running for the camber/caster adjustments? 3/8"? 1/2"?
      2004 Mustang LS2
      1964 Continental
      2014 Keezer
      Fwiw, drum brake hubs vs 2-piece and 1-piece rotor hub cast are right at 9/16" narrower in each side's width due to the drum hubs having the flat that much closer to the centerline of the car.
      You are looking at roughly 1-1/8" wider front track using 2-piece and 1-piece rotor hub cast instead of drum hubs.
      David Pozzi has pic's of both on his great 1st Gen. web site..
      And I have both drum and 2-piece hubs out in the garage..
      pdq67
      Nor Cal
      David Pozzi's page has endless info... impressive. I used this site (which has bene referenced numerous times on this forum when discussing 275s on the front of a 1st gen).
      http://www.geocities.com/casanoc/
      I used this as one of the references of a successful fitment of 275s using a stock front subframe.
      Other than the wheel maker using the wrong wheel size/measurements I do not know where I went wrong..
      2004 Mustang LS2
      1964 Continental
      2014 Keezer
