    Results 1 to 1 of 1
      Nov 2007
      Disc Brake bracket dimensions
      Hi all, I think I may have come up with a pretty good way to get good brake at a fairly reasonable price. Ive been eyeing the willwood 4 piston caliper that are axially mounted (they have the mounting ears) and along with a set of 13 inch c5 brake rotors and turning down my hubs I should have a really good brake setup without spending a ton on em. I want to make a set of mounting brackets and Wilwood has all the dimensions and measurements for the caliper but I havent been able to find any dimensions on the spindle side. I did see pozzis site with a picture of them but it just says to print the picture out to the correct size. Im hoping that one of you guys has a drafted drawing for the spindles, even if its setup for a GM caliper I could care less but I want to draw some up and have a pair waterjetted to try em out. Hope someone has this info :crosses fingers: OR IF YOU HAPPEN TO HAVE A TECHNICAL DRAWING OF THE ACTUAL SPINDLE THATD BE EVEN BETTER SO THAT I CAN FIGURE IN WHERE THE SPINDLE CENTER POINT IS SO I CAN DRAFT SOMETHING WITHOUT HAVING TO GUESS ON MOUNTING CIRCLE FOR THE CALIPER WOULD BE BEST
      ***Nevermind Wilwood sells the damn thing ready to go PN 249-7043/44****
