    Results 1 to 20 of 24
      Nov 2002
      Reading PA
      Hydraulic lifter went flat?
      I started up the 73 this weekend and took it around the block and noticed a pretty loud "tapping" somewhere on the front right top (#1 cyl). The car was running great but it sound like I have solid lifters, which I don't. I quick pulled the valve cover to see if the rocker was loose but everything looked OK. It's been too cold to go out and explore any further so while I wait for another warm day...
      Could I have a lifter going bad? What does that sound like? Any way to check without pulling the intake?
      Todd
      67 RS/SS Camaro (FOR SALE), 73 Camaro, 15 Jeep Wrangler Unlimited Rubicon
      http://www.fquick.com/qwik1320
      Feb 2007
      It could have gone dry and is not getting any oil to it. Also are you sure what lifter / rocker it was? Check them all and reset the valve timing with each one on the base circle. Also have a good look at your springs in case one has snapped. They are hard to see and stay looking intact till it all goes south.
      A lifter rarely goes flat on a run in engine. Initial start up is the crucial time for them.
      Sep 2002
      So. Cal
      Quote Originally Posted by qwik1320
      After running the engine, shut it off, rotate the engine to TDC. (or just off the cam) and push on the rockers (push rod side) If you can push it down, its not pumping up. Also see if you have allot of valve to rocker clearance at TDC. I've seen a flat tappet lifter wear 150" off of the cam face and got into the oiling reservoir. If you have good oil pressure to all the rest and none to #1, you will need to pull the lifter. I heard the main reason for this flat tappet failure is the material that was used. Typical for a manufacturer trying to save a buck in production. Once a tappet stops spinning on the cam, it's all over. Not to be Johnny rain cloud, but if this happened then your cam will need to be replaced as well. I would suggest at this point go with a roller conversion.
      Ron DeRaad
      68 Camaro RSx
      Darton Sleeved LS9 - 434ci (4.155x4.00)
      AFR LSX245 Heads (12:1cr)
      660hp/588tq
      Another thing to consider is the fact that todays motor oils are really not designed for flat tappet cams. I barely know about this to be dangerous, but through reliable hearsay Shell Rottella oil is the best to use for flat tappet engines.
      Oct 2007
      ridgefield ct
      todays oils are useless for flat tappets at break in (on their own) due to a lack of ZDDP. after that i can't get a straight answer, but VR-1 race oil is the only one still putting in lots of ZDDP. so you are definatly covered there. surprisingly synthetic is too good! it's so slick that the lifter won't turn. unfortunatlly rotella is now out as they also changed their formulation to environmental specs for the new diesels.
      Midwest
      Any info on the Rotella formula change?
      Kevin Oeste
      V8 Speed and Resto Shop
      V8TV
      Muscle Car Of The Week
      V8 Radio Podcast
      All about us:
      https://www.v8speedshop.com
      Woodland Park, Colorado
      I was told that the Rotella bottles that are blue/gold are the new formula without the zinc and the blue/white bottles are the old formula with the zinc.
      Quote Originally Posted by Atrain
      That makes sense, considering there are a ton of old truck on the roads.
      Boston MA
      Open up your oil filter and look for your cam lobe. It'll be in little metalic bits. Like others have said, it's a unlikely that it went flat if it broke in successfully. Good luck and have faith!
      1967 #s RS
      Nov 2002
      Reading PA
      Let me check things out. The engine is well "seasoned" and been through several broken valve springs over the years. It was running great, just sounds funky...and I'm not 100% positive it's a valve/rocker but it's definitely on the front right (as you look at, non-fuel pump side) of the engine so what else could it be.
      I did quickly look at the springs and didn't see anything but like you said it's tough to see them until they go. I also did quickly started the engine with the cover off and it looked like I had oil at each rocker but I didn't let it run long since oil was filling up and about to run over. I need to find a crappy valve cover and cut the top off. I'm running Quaker State 10W40, that's all that's ever been in the engine since installed in 87.
      Thanks for the reply guys, I'll poke around a little more when the weather heats up a bit.
      Todd
      i had the #6 cyl on my 327 go flat... after about 3k miles on the rebuild... not sure if the bore is bad... but made an awful sound... pulled the valve cover no loose rockers either.... but pulled it out... and it was rounded smoothe like a spoon. and the cam lobe was just as round. not sure what went first. if i remember correctly it was the exhaust side. cause it ran fine.
      breakin was 20 min at 2200-2500 rpm.
      put the same cam in and same lifter... switched to roller rockers.... no more problems but i can hear that lifter still trying to pump up.... the rest are ready to do...
      Dec 2007
      arizona
      i had the same problem lifter tapping after trying to set the lash 3 times i pulled the intake looked at the lifters 3 were worn so bad that almost a 1/4 of the lifter was gone!! i broke my cam in fine i guess it is the new oil this sucks time for a roller cam motor good luck with yours
      Im Using The Kendall 10/40 I Think... Ill Have To Check.
      Southern Indiana
      Ok so far the 2 to[ ZDDP high level oils are Chevron Delo and Shell Rotella T.
      As for the Bull$h-t of synthetic is too slick is pure crap.
      I have NEVER had any lifters NOT rotate due to synthetic.
      They are not thick or slicker they suimply have better thermal breakdown point, as its an engineered base oild with additives. No more No less.
      I have ran all three and still run synthetic and strenuously recommend them to anyone who likes to have long engine life.
      I can also say some people need to read up. GM has a bottle of additive called EOS its a suppliment and you can use it all thetime but I just use it on fresh flat tappet engines for the start and till the second full length oil change.
      If you use decent brand and grade oil you should not have issues. If you use a thin oil and dont treat the engine like its starting up new after sitting for several days/weeks.
      I see guys with engines having less than 50k miles, built on the 60s/70s theme and then treat it like a 90s/00s engine.
      If you have a late 90s up engine its designed to run with tighter clearances and thin oil if its built in the same vein as a 60s or 70s engine its designed for 10w40 20w50 and such.
      As for ZDDP being the only thing stopping cam wear thats BS and they are adding things that dont poison O2 sensors and cats.
      If you have an issue add some STP(its ZDDP rich and has more friction modifiers and viscosity improvers).
      I know guys running "house brand" oil and his cars sit, and he rarely has any cam issues (mostly his dads cars).
      If you use proper break in, use some of the cam lube suppliments and get some run time on it and change oil regualrly, AND remember to start it, and keep it idled up 1500 to 2000 for a reasonable amount of time after it sits several days. Get it warm, drive it as soon as it will idle (IE warm it up for 2 or 3 minutes, get some heat in the cylinders) and take off. Your going to get less wear on a cold start/drive than letting any engine run extended periods of time, anywonder why GM sets a 10 minute time limit on factory installed remote starts.
      Most never cars and anything with an ECM newer than about early to mid 90s will go closed loop within 5 minutes or less, generally as soon as the O2 lights up with proper cross counts and the engine is in the 140deg range.
      I have a carbed 355 in my truck and I simply get enough heat in cylinder to let stay running with no choke and take off.
      The drive from my trailer to the end of the road I live on is 1.6 miles and I can have my truck in the 130-140 temp.
      Oh and if a lifter doesnt spin the bore probably have burrs or something.
      And again I have never had any issues with lifters that didnt spin and go flat unless they never passed a hardness test.
      Oct 2007
      ridgefield ct
      my info on the synthetic came straight from comp cams. the flat tappets, especially the XE series seem to be very picky when it comes to oil. they used to recommend the rotella t synthetic and the delo and then had problems. now they only recommend VR-1. as to ZDDP levels, everytime i researched it i got fewer and fewer results.the only brand anymore that actually says they use it (at least in suffficient quantities) is VR-1. the additives in modern oil are designed to protect roller cams, not flat tappets. they worry more about OEM requirements than aftermarket. especially since a flat tappet hasn't been used in a new car for what, almost 20 years?
      i'm now hearing that compcams recommends that you get the cam nitrided due to the oil deficiencies. and they are again recommending rotella in the right container/blend.
      does anybody have hard data regarding ZDDP requirements after break in on flat tappets? especially the XE series?
      Sounds like another reason to switch to Gen III/IV engines...LOL
      Oct 2007
      ridgefield ct
      if i had any money....
      Quote Originally Posted by megaladon6
      Honestly, there are ways to do it on a budget.
      Oct 2007
      ridgefield ct
      if i had ANY money....
      i just built an engine and i need to get suspension, wheels, brakes, body work, EFI, exhaust...
      When people start talking about installing EFI on older engines tahts the point where an LSx makes the most sense, financially.
