    Results 1 to 12 of 12
      Drive by wire mounting
      I posted this in the wrong section earlier,Im putting a LS-2 in a 69 Camaro and was wanting to know how everyone mounted the pedal assembly to the firewall?......
      Maine
      I'm interested in this question too... especially since if you put a bolt through the bottom mount hole of the pedal (from an '05 GTO), the head of the bolt limits the pedal travel.
      John
      Colorado
      So nobody has ever done this??? I was hoping for a picture or alittle advice also.
      68 Camaro
      LS2 6speed
      Complete Hotchkis front and rear suspension, Global west SFC, 3rd gen steering box, C5 front rear discs w/ 4th gen booster and MC. 8.5" posi rearend with 30 Spline 12 bolt axles.
      Jul 2003
      Anaheim Hills, CA
      I did it.. but it's a secret.. shhhhhh
      j/k
      Ok.. two ways to do this. The first requires that you repaint the firewall. Make a plate and attach studs to it so that hte pedal can mount to the plate. Then weld the plate to the inner firewall in the right location so that the pedal falls in the correct spot.
      The other way is to bolt the plate to the firewall (rather than weld).
      In either event you will be able to remove the pedal assembly incase it needs to be replaced.
      Make sense?
      1968 Track Rat Camaro:
      Miamisburg, Oh
      how about some JB Weld on that plate? ;)
      Chicagoland
      Button head cap screws, stainless.
      Jeff Schwartz 815-770-0751
      SchwartzPerformance
      Where classic style meets modern performance.
      455 Commanche Circle
      Harvard IL 60033
      SchwartzPerformance.com | Facebook | Twitter
      Feb 2008
      dang yall really like the dbw stuff i got some i need to unload im on ls1tech alot some1 should holla at me on there same name
      Lafayette, La
      Im with Jeff_s on this one
      Colorado
      Whats the ideal mounting position for the pedal? In terms of heel toe driving, and comfort. how close to the brake should it be? the same height or lower than the brake? any suggestions? I already sold my old pedal so I cant really remember where the old one was mounted.
      68 Camaro
      LS2 6speed
      Quote Originally Posted by Midnight68
      Here is a page from the new GM Performance parts harness instruction sheet. It lists some guidelines for positioning the gas pedal.
      Janesville, WI
      Great info Andrew. How many pages is that GM Performance parts harness instruction? Would it be easy enough to post up, or is there a link to it?
      -Shaun-
      L92/T56 Stalker 1711 pounds, LS power!
      73 Buick Century L92/T56 swap in progress
      Quote Originally Posted by subtlez28
      Someone on LS1tech.com posted it. Here are the other 3 pages.
