Results 1 to 17 of 17
Thread: what line size????
01-07-2008 #1
- Jul 2006
- Hackettstown, NJ
- 1,026
what line size????
Need help trying to figure out how to determine what size fuel line run and return. Currently the setup is for a Holley projection 4 system and plan to switch to multi port in the future once the bank account recovers. Expected current power levels are 550 hp and 600 ft*lb. engine is a Pontiac 455 (474) max rpm around 6000. I plan to install a fuel pump and sending unit out of an LS1 equipped f body since it has an inline pump( I can change to a walbro type pump if needed). Coming out of the tank is currently 3/8 feed lines and 5/16 return lines. I can run up to ½” to the throttle body. Current set up requires 14 psi, MPI requires 45-60 psi. is it possible to do this once or would I have to redo the system w/ the MPI. I have not bent any lines yet. However, I ordered a 7/16 feed line a while back, but it wont fit properly due to frame modifications. Also, AN fittings are not made in that size. I’ll use that for another car.
Questions
Feed line size?
Return line size?
01-08-2008 #2I think you would be cutting it close (or run out) with the 14psi thru the 3/8" line. Using the 3/8" supply/5/16 return, higher pressure pump and regulating it down at the Holley Unit would be a safer way to go. Otherwise I would use the 1/2" supply and 5/16 (or 3/8 for AN fittings) return with the 14psi.
Ron DeRaad
68 Camaro RSx
Darton Sleeved LS9 - 434ci (4.155x4.00)
AFR LSX245 Heads (12:1cr)
660hp/588tq
01-09-2008 #3
- Sep 2004
- Kettering, OH
- 537
I did an EFI Pontiac in a Firebird and went with 1/2" supply and 3/8" return. You better have some good tools to work with 1/2" steel and especially SS. There are folks here running that HP with 3/8" line. It would be far easier than 1/2" I have details on my system here: http://john.my67.net/efi.htm
01-09-2008 #4
