    Thread: Stuck in gear..
      Copenhagen
      Country Flag: Denmark
      Stuck in gear..
      Hi
      I have a 67 firebird, with a Super T-10. Sometimes when I'm pulling hard in second, the car gets stuck in gear. After a little while pulling the stick, I can get it in neutral. The trans has a hurst shifter. Any ideas what's wrong ?
      thanks stefan
      Jun 2005
      bad clutch pedal linkage? or bad syncros in the tranny? Honestly, i'm at a loss... makes me wonder why i responded... LOL, sorry i'm not much help.
      Copenhagen
      Clutch is working perfectly
      Make sure that the shifter is adjusted properly. There is a pin that goes into all the levers in the neutral position. All the rods should be adjusted with the pin installed and the shift levers in the neutral position.
      Feb 2007
      USA, TN
      Had a similar problem with a 3speed. The shifter was not adjusted correctly.
