    Results 21 to 40 of 41
    1. #21
      Dayton Ohio
      nice work man
    2. #22
      St.Anne Il
      back seat usable..yeah right ...my back still hurts from the ride in your other camaro on power tour..lol..bout time you updated ..getting moving ..better be ready by sept..lol
      Darrin Stalnecker
      2007 Corvette Supercharged
      1968 Camaro LS1 T56
    3. #23
      Jun 2006
      NW burbs IL
      The easy way to weld the upper portion of the down bars.
      Chassisworks crossbar clevis
      Installed ( I need a Miller welder )
      Install done, except for cleaning up some of the welds and maybe adding some small bars to the shock point on the DSE tunnel.
      Matt
    4. #24
      Aug 2002
      Waleska Ga.
      Nice job Matt
      You going to have it at the RTTH this year?
      David Sloan
    5. #25
      Jun 2006
      NW burbs IL
      Thanks for the compliment David.
      Yes I plan on being there, but first I plan on hitting the HRPT and doing some racing with the local club.
      Matt
    6. #26
      IL
      Very nice work. Matt how do like the way the Q link ride is? What shocks are you running? Keep the pictures coming.
      Rick
    7. #27
      Jun 2006
      NW burbs IL
      Its funny you ask, I like it but just found the instructions on how to adjust the rear Koni shocks. I bought the shocks from DSE with the rear suspension. I was in such a hurry to drive the car last fall I just put them on and never even thought to check where the adjustment was. It rides nice but I do remember it was harsh on large bumps. I'll find out soon where they are at in there adjustment and try a softer setting ( if there is one ) One thing I can say is the car handles excellent, better than my 95 with konis.
      Matt
    8. #28
      Jun 2006
      NW burbs IL
      I'm going to save the oem upper rear panel.
      First I had to make a slapper bar and get a real hammer and dolly set. Here is the slapper I made, yes ugly but it works. I have already started to work the panel in this pic. I am also using a shrinking disc to shrink and stretch it back into shape.
      I hit the point of needing a break.......... So I started on the Quarters First off with the false quarters the previous owner installed.
      test fitting then file, grind, adjust repeat . repeat . .............
      I had to repair two tears in the tailpanel prior to working with the pass quarter.
      And after 40 some hours just fitting the two quarters and tulip panel I almost ready to see how the new roof fits.
      The tail panel looks worse than it is, Its wavy but they are smooth waves vs. the orginal beat to a pulp look. Once the panels are welded back on I'll use the shrinking disc to bring it back to original specs with no need for bondo, just a primer filler.
      Matt
    9. #29
      Girard Ks
      Looks good man keep up the good work.
    10. #30
      Rockford Illinois
      Man those pics bring back memories of my cage install and sheetmetal repair . I thought when I got to the paint I was 1/2 way done only to find out it was with the work and then the $$$$$$ started to come into the picture big time.
      Looks good soooooo far
    11. #31
      Nov 2007
      Looks good! There's nothing like 40 hours of fitting to do 5 minutes of welding!!!
      Ron
      69 Camaro Redfire, thanks to
      Marquez Design | Ring Brothers
    12. #32
      CHICAGO SUBURBS
      When you're finished I'll have some more work for you to do. Get to work!
    13. #33
      Jun 2006
      NW burbs IL
      Frank,
      I decided to use metal adhesive for the drip rail and tulip panel area. I started to think hey if I just glue everything like a big model I'll be done in no time. lol
      Matt
    14. #34
      Jun 2006
      NW burbs IL
      Tim Taylor moment Argh! Argh!
      I picked up a new 2008 L92 which will go in next winter. All aluminum 6.2L ( 378 ci ) vs. 2001 LS1 5.7 ( 346 ci )
      I'm closing in on panel alignment
      Some slight mods will have to be done at the roof corners.
      Matt
    15. #35
      Nov 2000
      O-town
      Looks Great Matt, great job right in the garage!!!
    16. #36
      Feb 2006
      Southern California
      Nice work! I'm in the same boat. I will be doing the same this summer! keep up the great work and keep the pics coming....
      Ron
      "If at first you don't succeed Skydiving is not for you"
      1970 Z28
      Scott Mock C6 Subframe, Ridetech RJoint 4 link
      LSX454
      Anvil Auto - through the build
    17. #37
      what is/was wrong with "false" quarters? The guy who did my "false" quarters talked me into retaining as many of the factory seams as possible (rust wasn't an issue) so I took his advice and didn't do full quarters. Now you have me second guessing myself. Just a personnal preference thing or did I make a mistake?
    18. #38
      Jun 2006
      NW burbs IL
      Quote Originally Posted by lowboy
      I'm very picky, the one quarter had some oil canning and the time it was going to take to make certian areas of the previous roof repairs look correct lead me to just start from scratch. Also considering the money I have in the car, another $1500 dollars for all new uni-body sheetmetal was a no-brainer.
      Matt
      Matt
    19. #39
      thanks for the reply..
    20. #40
      Jun 2006
      NW burbs IL
      Here are a couple of pics of the b.s. I'm going through with the new inner wheel wells, they were installed when the false quarters were put on. While fitting the full Goodmark quarters I found they dont line up correct. My solution has been to fit the quarter then slice just about the inners lip and add metal to bring it into the correct position. The pics make it look like hell, but once done it will be a seamless job.
      The left side was only off and small amount and just required stitch welding up the slice. The right required about 1/2" of metal added at the widest portion.
      Here are pics of the right
      Matt
