      2nd gen question????
      can some one tell me what the biggest and widest wheel i can fit into a stock wheel well on a 71 camaro, would be? I would like to run a 19 inch wheel. It is not a problem to narrow the rear if i have to. thanks conbread
      May 2002
      Northern California
      285 to be absolutly rub free, 295 will work but fit is tight. 315's fit but you can't lower the car much, tire sits below the lip.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      hey thanks for the reply mrquick. what size wheel and tire is that on the blue camaro in your pics. thanks conbread.
      May 2002
      Northern California
      no problem.
      Rear it was 285/17 on 17x 9.5 with a 5 5/8" back space.
      Aug 2006
      Quote Originally Posted by conbread
      My car had 20s on the back and lowered, but I believe they were 8 inch wide. I have done a lot of research regarding the wides wheels and backspacing, it seemed like most people run the 17x11 wheels with 5.75 backspacing, but you need to roll the fender lip and beat the hell out of the seatbelt hump.
      I ordered my 17x11 Torque Thrust IIs, 5.75 backspacing. I have not received them yet.
      Also depends on the type of tire you are using. Some tires have round shoulders like Nittos and Sumitomos, and some others like Goodyear F1, D3 tend to be wider than Nittos and Sumitomos
      72 Camaro RS:SOLD
      68 Camaro:
      LS6 Engine,Tremec TKO 600,5 Speed
      Complete Speedtech Subframe Kit,Speedtech Torque Arm, 9" Rearend from Strange, Wilwood Brakes, Minitubbed, Hotchkis Subframe Connectors
      gainesville ga
      Quote Originally Posted by MrQuick
      no problem.
      I thought AR only did backspacing in 1/4 inc.
      Shaun McCarthy
      68 camaro
      May 2002
      Northern California
      custom bubba....you can call them direct and order as needed.
