Results 1 to 13 of 13
Thread: Pulling engine trouble! Help
Starting The Transformation
- Nov 2005
- 180
Here you go
1st remove distributor cap,(or the whole dist.if thats coming out anyway)
2nd loosen motor mount bolts(center through bolt)
3rd place floor jack under trany(with jack handle toward rear of car)
4th remove trans crossmember and lower jack (trans) about 4" or so
5th now from the bottom,with a long 3/8 drive extension 20"-30" long with a 9/16 swivel scoket,the top to bolts are just as easy as the others
Camtender,Privateer by choice
Member of Hot Rod Power Tour Long Haul Gang 03'
Winner of the 2nd annual Pro-Touring.com Run Thru The Hills drag racing event sponsored by Musclerides.com 06'
2nd in class @ Big Bend Open Road Race 07' http://www.youtube.com/watch?v=Nti3UarUwzU
Record holder @ The Texas Mile 08' for 1st gen. camaros http://www.youtube.com/watch?v=lvEzlnnAB8I
http://www.youtube.com/watch?v=6L0sYaMnni4
