    Results 1 to 13 of 13
      Flo-rida
      Pulling engine trouble! Help
      Well im looking at the transmission and how do you get to the 2 top bolts on the case to the engine? Theres no room to get a wrench or socket in there. I was thinking about unbolting the transmission from the crossmember and sliding the engine to the front with the hoist and getting it that way.
      What do you think? Any other ways? I dont want to take the transmission out with the engin.
      -Rob
      1993 Camaro Z28
      2001 Camaro Z28
      1969 Camaro
      May 2002
      Northern California
      not even a gear wrench?
      yeah, you can do it that way. I've removed the motor mounts and the motor will come down a bit. What car?
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      St.Anne Il
      i got a gearwrench that is bent in like a 45 at each end at sears..works great..those 2 bolts do suck though...
      Darrin Stalnecker
      2007 Corvette Supercharged
      1968 Camaro LS1 T56
      Flo-rida
      Quote Originally Posted by MrQuick
      Its a 69 Camaro. Honestly i cant see the bolts from under neath the car. The tranny tunnel is about 1/2" from touching it.
      1993 Camaro Z28
      2001 Camaro Z28
      1969 Camaro
      Rockford Illinois
      I have always found it to be a lot easier to pull them out togehter. Getting it back together from under the car is a real pita. I have done it all by myself pulling and installing them together but apart you with be screaming for help. I use a floor jack to raise the tranny to clear the crossmember as I take it in and out and with the car on flat ground you can pull or push the car to position the motor as you go along and also moving the hoist at the same time if needed. I know you think it might be harder but it is also much easier to make sure everything is back together right and nice and clean.
      Make sure your get a plug for the output shaft of the tranny and it will make things a lot easier.
      Otherwise the 2 bolts you are talking about come loose from the top easier than the bottom and a gearwrench will do it from my experience easier than the turn and flip 100 times with an open end!!
      Goodluck and stay calm
      May 2002
      Northern California
      wow that is close...usually you have more room than that...you can get hectic and loosen the subframe mounts and slide it foreward.
      We got hacky on my buddies 440 Challenger by drilling 3/4" holes in the firewall and covered them with 3/4" plastic plugs. What can I say we were young.
      Flo-rida
      lol well im at that young stage to but im not about to pull out a hole saw and go crazy haha. And yea it is very close. Do TH-350s have different size cases or something because its tight against the tunnel.
      1993 Camaro Z28
      2001 Camaro Z28
      1969 Camaro
      May 2002
      Northern California
      Quote Originally Posted by Project69
      maybe the subframe bushings are worn? might just be misaligned too?
      Here you go
      1st remove distributor cap,(or the whole dist.if thats coming out anyway)
      2nd loosen motor mount bolts(center through bolt)
      3rd place floor jack under trany(with jack handle toward rear of car)
      4th remove trans crossmember and lower jack (trans) about 4" or so
      5th now from the bottom,with a long 3/8 drive extension 20"-30" long with a 9/16 swivel scoket,the top to bolts are just as easy as the others
      Camtender,Privateer by choice
      Member of Hot Rod Power Tour Long Haul Gang 03'
      Winner of the 2nd annual Pro-Touring.com Run Thru The Hills drag racing event sponsored by Musclerides.com 06'
      2nd in class @ Big Bend Open Road Race 07' http://www.youtube.com/watch?v=Nti3UarUwzU
      Record holder @ The Texas Mile 08' for 1st gen. camaros http://www.youtube.com/watch?v=lvEzlnnAB8I
      http://www.youtube.com/watch?v=6L0sYaMnni4
      Flo-rida
      Nope replaced them with poly bushings no drop.
      1993 Camaro Z28
      2001 Camaro Z28
      1969 Camaro
      Southern Indiana
      What camtender said
      uh,sure no problem??
      Flo-rida
      Its cool i got it out and torn down today. Now its off the machine shop. Thanks for the help guys.
      1993 Camaro Z28
      2001 Camaro Z28
      1969 Camaro
