    Results 1 to 20 of 58
    Thread: Fuel Filters
      Nov 2004
      Colorado
      Quote Originally Posted by andrewb70
      I would like to see some data to back up this statement. This filter has been used, in conjunction with a Walbro 255L/hr pump, to feed a 600HP (flywheel) 496 big block chevy. I suppose if you had a 1000RWHP engine you would need something else, but for the 90% of builds out there, this filter will work just fine.
      As for using the 2001 truck filter, I believe it will have the quick disconect style fittings on it. That will make it more difficullt to integrate into your fuel system.
      No data, but consider this. That filter has at most a 10 micron paper element. There is no free lunch, and a 10 micron filter that size is going to be a restriction with its low filter area, especially when it gets dirty. Restrictions in the fuel system cause heat build up in the fuel. I have been battling heat saturation in my car and have replaced every "it should be big enough" part with overkill parts.
      Los Angeles
      Quote Originally Posted by EFI69Cam
      Thank you. I was concerned about this relatively small surface area, and the flow demands of the bigger engines.
      Not to take anything away from the 'vettes, but a 350 making 400 hp and a 454 or larger, making 600 or more hp, is a big, big, difference in fuel demands. Especially when you consider that many built BB engines are not as efficient, so their BSFC goes up, and therefore the fuel demands (volume).
      Quote Originally Posted by Karch
      I will say this again. This filter has been used countless times on a big block making 600HP, with no pressure drops at WOT.
