Results 1 to 12 of 12
Thread: LS2 Questions
07-26-2007 #1
LS2 Questions
I'm new to the ls platform and completely in the dark so to speak. I'm starting a new build of a '72 Camaro and picked up a good deal on an '07 LS2. I registered over at ls1tech but the e-mail hasn't come through to allow posting yet so I figured I'd ask a few newb questions here.
The engine was removed from an '07 vette convertible, the owner swapped in an LS7. To do the conversion they used the parts neccesary from this engine to convert the LS7 to wetsump. No problem with that as I needed an F-body oil pan and pick-up for my swap anyway. So I went to the GM dealer and purchased an F-body pan, pick-up, dipstick and tube, along with a new LS2 timing cover. I'm extremely comfortable with gen 1 small blocks and builds but know nothing about these so I purchased the shop manual for the '07 vette to have all of the torque specs, sequences, etc.
My first question: Are the specialty alignment tools neccessary for the timing cover and oil pan replacement? On the gen 1 this is not needed or done. 2ND question: What oil pump if other than stock for the LS2 is suggested and why? The original pump was used in the LS7 for the conversion. 3RD question: The service manual states to mark the balancer when removing as they are not keyed like the gen 1, I have not checked to see if it was marked when removed, but if I will be using an aftermarket drive set-up such as the one from ATS will this matter? Last parts question: This engine has the 58X reluctor wheel and came from a car with an auto trans. I will be installing a manual, will any LS type flywheel from Mcleod or others work or is it specific to order for an LS2 with the new style reluctor wheel? I don't know if there are dimensional differences between the cranks where the flywheel mounts or if the balance would be different.
I'll probably have a lot more questions as I go along, sorry to be long winded. I just like to get informed as much as possible when dealing with a new unit such as this.
Tommy
