    Results 1 to 9 of 9
    Thread: caddy LS
      Apr 2007
      Odenton MD
      caddy LS
      Is the caddy motor the same as the fbody motor (the caddy has front wheel drive)
      Dunwoody, GA
      Yes, there are just some differences in the oil pan and accessory drive system due to the different platform. Aside from that it is an LS6 or 2 just like all the other cars.
      Trey
      ~ Jon Hammond
      Apr 2007
      Odenton MD
      So because of the different drive set up it wont work in my fbody
      San Antonio, Tx
      you just have to use your set-up.
      Instagram: CamaroAJ
      Quote Originally Posted by tb8125
      What Caddy engine ar eyou talking about? The only Caddilac that I know of that uses an LSx engine is the CTSV, which is RWD.
      This might help:
      http://media.gm.com/us/powertrain/en...2007/07car.htm
      Dunwoody, GA
      Very true Andrew. I am assuming he is talking about a CTSV and is looking at an LS6 or 2.
      tb we need more info. What year firebird are we talking about? What year CTSV and engine are we talking about? You are being way too general. The Gen 3/4 engines are basically the same on the outside. So swapping the Cadillac front accessories and oil pan to LS1 fbody stuff is no big deal. However, are you working on a 4th gen or a 1st, 2nd, or 3rd?
      Trey
      ~ Jon Hammond
      Oct 2005
      Olathe, KS
      The FWD cars use the Cadillac-exclusive Northstar. You can get conversion kits to put a longitudinal tranny behind them, but the swap isn't as common as LSx swaps.
      -Chris
      '64 Impala Sport Coupe- Slow-Touring project; LR4, 700R4, work in progress
      '66 Corvair Monza Convertible- 110, Powerglide
      '95 Z28- 355 LT1, 76mm turbo, built 4L60E, 12-bolt
      '98 S10 scsb- 4.3 auto
      '00 Corvette coupe- 6-speed
      Apr 2007
      Odenton MD
      when I goto the yard I will get more info
      Also the balancer is different , something to think about in the cost
      and if it will work with the fbody/vette acc. Go to the CTS V
      forum's on LS1 Tech lots of info on the differences.
