      Which T56 is it?
      I found a T56 that is supposedly out of a 03 or 04 GTO, it has the slave cylinder around the input shaft and the bellhousing bolt hole in the 2 o'clock is missing. Also the shifter is way back even with the output shaft. I have been reading a lot of your posts about transplanting a six speed into an older car, is this trans a lot of trouble. The only thing I know about six speeds I learned on your website. I have seen a lot of posts about the older T56's but none on the newer model. Any help would be appreciated.
