      Ignition source for spal controller and Fans
      Hey just a quick question. I have my spal controller and relay set up on my core support on my 67 camaro. I need to know what wire you are splicing into for the ignition source wire. Or are you running a wire through the firewall and to the fuse box.
      I think running a dedicated ignition wire back to the fuse box is the best idea.
      [email protected]
      Melbourne, FL
      I plan on having a seperate fuse block with a relay off the ignition. My plan is to pull power to the extra block from the battery but use and ignition keyed source to work a realy to activate/deactivate the power to the block. Just an idea I'm kicking around for extra ign/acc circuits.
      67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
      Honest dad that 455 on the side of the block is a serial number
