Results 1 to 11 of 11
Thread: Rear End ratio help
- Aug 2004
- Pittsburgh, PA
- 316
Carl has it right...
I gotta agree with Carl. With that much grunt down low I would be looking at a 3.42 gear also. With the 3.73s and that much torque you are not going to like the wheelspin (uhhhh...I mean 1st) gear.
Shane
12-21-2004 #2
Banned
- Aug 2003
- Orlando, FL
- 8,745
I like a 3.42 because
Fluid Private messaged asking me to review the post for my opinion, so here goes.
With a 3.42 you have the best all around. You have an effective starting line ratio of 10 to 1, which for reference, is lower then a 69 Z28 or 70 LS6 Chevelle (9 to 1) with a 4.10 (Muncie had 2.20 1st ratio), so you will have great low end grunt still, but not so much that you over power the tires all the time. Any lower gear may make the car to torquey to launch. It also would force a shift 20 feet from the traffic light, you probably would end up leaving in second often when you feel lazy.
On the other side of the coin, I like the 3.42s on the highway because at 60MPH you will tach 1670, and at 70MPH you will tach 1950. I suspect for your motor to be 400+hp, the cam duration is around 225 to [email protected], which means it would actually still lope at anything lower then 2000RPM or so, and loping and chucking at cruise speed is miserable, you could end up finding yourself in 4th gear a lot. I also suspect like most of us, you probably cruise at 77MPH more often then 70, so you will be a couple hundred north of 2000 at cruise. Based on the cam specs, (if the cam is over [email protected]), I may change my mind and recommend a 3.55, and unless the cam was over 240@50, anything lower then a 3.55.
12-22-2004 #3
- Aug 2004
- Columbus, Ohio
- 117
Cam specs
The motor was built by Golen Engines in N.H. Great guy to work with.
Here are the CAM specs
Intake is 224 @ .050 lift = .477
Exhaust is 230 @.050 lift = .480
Looking at the Dyno chart, it makes 400ftlbs at 2250 rpm. not 1750 like I had previously mentioned.
More input is welcome! Thanks!
DarrenLast edited by Fluid Power; 12-22-2004 at 01:21 PM. Reason: added to post
12-22-2004 #4
Banned
- Aug 2003
- Orlando, FL
- 8,745
Looks like my guess
Looks like my guess of 225 to 230 was pretty damn close. I stay with everything in my previous post. You will be happy.
