    Results 1 to 20 of 27
      looking for an engine
      im looking for a drive train for a light weight performance vehicle...
      the criteria are....
      Inexpensive light weight high revving 4 cylinder
      rear wheel drive platform
      carbureted
      readily available replacement/ performance parts
      manual transition
      So far I’ve strongly been leaning towards a 22r from a 2wd toyota truck any other ideas?
      Harriman, Tennessee
      Although it was originally a FWD motor, I have seen several articles on the Quad-4 being built up for a RWD performance application. There are a good deal of aftermarket parts to adapt carbs, trannies, etc.
      Shiny Side Up!
      Bill
      '72 442 "Inamorata"
      '89 ASC/McLaren
      www.FQuick.com/ProTouring442
      "You can never go home again, Oatman...
      But I guess you can shop there."
      Feb 2007
      East Freetown, MA
      The newer motors out of the Pontiac Solstice's are also supposed to make big power with a turbo..
      Apr 2002
      I agree with Chris. See ebay item 320110173707. They usually have several per month around that price.
      --JMarsa
      Feb 2007
      Cobalt 2.2 litre engine?
      Oct 2005
      New Washington, IN
      Pinto motor! Plenty of aftermarket support for it.
      Sep 2002
      San Jose, CA
      I'll second the 22R - just a bulletproof engine with a ton of aftermarket stuff out there.
      Lots of the SCCA Starlet guys buy used Atlantic Cup engines and make a TON of power
      Just call me Brett
      Texas
      I agree with Bill. I'd go with the olds Quad-4.
      The older ones are 2.3 liters, the newer ones are 2.4 liters.
      The power steering pump was driven off the back of one of the cams (if I remember correctly). That would be a good place to drive an old 4 cylinder distributor. Install a set of weber IDF 48mm carbs and have a cool set up. Tweek the factory electronics, install a turbo and 400 hp is easily possible.
      GM performance parts makes lots of goodies for that puppy, so it just depends on how much you want to spend.
      A bell housing from an S10 truck should have the same bolt pattern. The old motors were 2.5, the later ones used 2.2s and the old V6s were 2.8liters. All of those had the small bell housing, the later 4.3 S10 engine is the same as what the 350 has.
      The 22R is good for what it is, but not much for all out performance. The 2 valve head is its limiting factor. The Quad-4 has 16 valves and uses a cam/bucket design. Good for amazing performance and high revs.
      what cars did the quad come in?
      this would be going into a very light track T roadster. V8 might be a possibility now though.
      we don’t want to get into fuel injection with this project so nothing late model will be in the cards unless its converted to carbs. And something with a distributor is also required.
      I like the idea of the 22r because with some Webbers hanging off the side they actually look really nice. I may also go with an MG B motor (have you seen how stout the block is on one of those?!?)
      Sep 2002
      San Jose, CA
      Just call me Brett
      Harriman, Tennessee
      http://www.hotrod.com/techarticles/o...rts/index.html
      I also think Street Rodder did a series of articles on the Quad, including carbs, finned timing covers, and other cool stuff, but I can't seem to find anything. I remember they talked about how you could make a Quad look a lot like an old Offy.
      Shiny Side Up!
      Bill
      '72 442 "Inamorata"
      '89 ASC/McLaren
      is the pinto engine the same 4 thats in the mustangs and t birds?
      how easy are these to come by?
      just trying to weigh out all of the options
      Harriman, Tennessee
      Quote Originally Posted by RobM
      Yeah, it's pretty much the same engine as far as I know.
      Hey, what about a BMW 3 series 4-cyl? DOHC, and the earlier ones come with carbs.
      Just a thought.
      Shiny Side Up!
      Bill
      '72 442 "Inamorata"
      '89 ASC/McLaren
      that would be cool a bmw engine would make a one of a kind vehicle.
      Any carb kits for miata engines?
      Texas
      A track-T roadster? How about an old flat head V8? You're wanting it to look "old-school"? That would be the ultimate. I know of a local salvage yard that has several to choose from. Have you ever seen one? Those engines are tiny, I've seen aluminum finned heads on e-bay.
      You'll get a lot of flack from using a Jap engine in an American hot rod. Stay away from the ricer motors.
      An old Ford car deserves a Ford engine.
      Plans for a rat rod, or will it be nice cruiser?
      flat head would be cool. yes I’ve seen one I’ve been around and working on traditional hot rods for a while. the reason i want a 4 banger is for a few reasons.
      the track T's traditionally had 4s in them.. before the flat head v8 was in production
      this car has to be able to drive cross country with out a hiccup OR spending more money then it cost to build the car in fuel
      this isnt going to be a fat tired billet cruiser. its going to be built in a period influenced style
      as far as keeping it all ford I’m to not too concerned with that the essence of hot rodding as far as I’m concerned is putting more power into your car, an what ever brand parts this happens to take to do this, is irrelevant. I think a 32 roadster with a blown hemi in it is just as cool as a flat head if not cooler. Or a T bucket with a Buick nail head is more interesting then a ford with a ford engine
      I dont like to call them "rat rods" to me a rat rod is a hunk of crap that is unsafe to drive on the road
      to me its just a hot rod built right
      Texas
      I agree w/the whole rat rod ordeal.
      I guess I meant low budget: Something really nice, driveable and w/o all the billet stuff that takes away from the fun of it all.
      I can see where reliability would be an issue. So, simpler is better.
      I guess as long as it looks cool and goes down the road, it's all up to your imagination (and parts availability).
      If it was my choice I'd do the Bimmer motor, but not the Toyota.
      Good luck.
      we shall see. right now were in the parts gathering stage. im still looking for a good body. or at least a nice cowl and fire wall to start with. I'm planning on improving on the lack of room in a typical bucket.
      Boston MA
      Either the 22R or the Pinto 2.3. Both have a ton of market support and are used extensively in racing. Circle track magazine did an article on building both motors a while ago. I think some of it is on their website. Good place to start. I'd avoid the other options in an effor to keep things simple.
      1967 #s RS
      Maine
      I've been thinking about building a small open wheeled toy myself and considered some of the engines above, but am also considering using a 2-stroke snowmobile or perhaps a motorcycle engine.
      There are many choices that will rev to the moon and will probably weigh half (or less) than the car engines described above. Granted, most of these only displace up to about 1200cc, but many still make well over 100 horsepower. You can pretty inexpensively go out and find a whole running snowmobile or motorcycle and pull the engine and transmission and then you just need to fab up a chain-driven differential for it. Then you also have the entire fuel and electrical system as well.
      John
