      Oct 2002
      Houston,TX
      Y block on fuel lines or not
      If I just run the fuel line into one of my rails and then run a crossover to the other and then a line out of it to the fuel regulator is that any different then running a Y-block then a line to each rail and then two lines to the regulator?
      James J.
      Jun 2005
      Yes, in the first scenario you mention, the 2nd rail is not receiving an equal volume of gas, as the 1st rail has already consumed part of it. That being said, a lot of systems are set up that way, and unless you have something unusual, like a high-HP bosted system or something, you probably wouldn't notice a thing.
      Jim
      Half-Assed = Half-Fast
