    Results 1 to 10 of 10
    Thread: Liberty Gears
      Liberty Gears
      I was wondering if anyone has any Exp. with clutchless trannys, and what are the good and bad of them.....
      I talked to TKO and told them my engine combo " they told me it would be a waste of time to put a tranny from them in my car " so they gave me liberty gears number and I talked to them and told them the same thing and the TKO's and T-56 they build would not work either, but they did say a cluthless tranny would be the best bet, and they would make it a 6 speed instead of a 5 speed....
      Pro-Stock "Z" Style Transmission$8030.00Rated at Approximately 1500 Horsepower at 2500 Pounds or 1100 Horsepower at 3500 Pounds -Magnesium Case-Magnesium Tailhousing (Bushing or Roller Bearing)-30 Spline 300M Mainshaft-300M Input Shaft-Higher Efficiency Gear Profiles-High Gear Removable Face Plate Engagement-5-Lug Engagement (All Gears)-Exclusively V.A.R. Material
      http://www.libertysgears.com/clutchless.htm
      any and all advice is welcome
      Manitoba Canada
      what kind of car and what are you trying to do with it??? a clutchless trans is USELESS for any street aplication, its drag race only.
      have you looked at G-Force - the GF5R is a great trans
      Detroit Subs
      More info about your set-up is needed, but I would listen to what Craig @ Liberty says. He is VERY knowledgeable!!
      It will be going in a 78 trans am, with a butler performance 571 CI aftermarket block, hp range is over 1200 and torque is over 1000, aftermarket front sub frame, ( might be going with a full frame undecided at this time ) the list goes on and on,
      Manitoba Canada
      ..........so your going drag racing????????????????????????????
      Detroit Subs
      Because of the tq numbers, noone selling transmissions will say to put anything other than a full boogie race trans in the car. Your comfort is not what they care about, it is simply a matter of if the part they give you will live or not. A lesser trans may work - but for how long, etc. ??
      May 2006
      with that kind of power you might have to go 4l80, lenco or PG w/ gear vendors setup.
      it will be for part time drag and the rest will be shows etc, I talked to g-force today the GF5R will work, as a cluthless set up, and is rated at 1200hp, they did say they will get me a seperate clutch assit box, so it could be driven on the street......
      Manitoba Canada
      good thing your pockets are deeep, I wish i could afford 1 GF5R, let alone 2..............
      Quote Originally Posted by 78TA197
      Have you ever driven a dog-ring transmission on the street? If this is trully to be a street car that will see limited use on the track you should reconsider your choice of transmission.
      For the record, the Liberty pro-stock transmission is REALLY not suited for the street. It cannot be downshifted. You must come to a complete stop, reset the shifter so that it is in the up position. Only then can you go through the gears again.
