    Results 1 to 9 of 9
    Thread: Mini V8
      Shelby Twp./EL, MI
      Mini V8
      http://www.weberprecision.com/weberprecision1_015.htm
      This page will describe the construction of a miniature eight cylinder engine I built in my home machine shop over the past few years. I still have a few small details left to finish, but the engine is running and almost complete. This was my first attempt at building a running miniature engine, I should have started with something a little simpler. I had a great time designing and building this engine and the first time it started was an unbelievable experience. I am going to take the engine back apart over the next several days to modify it for running on racing fuel or alcohol, I haven't decided which yet, I will be increasing the compression ratio by milling a bit more material off the cylinder heads. I will take pictures of all the internal components and post them here along with how I went about machining the parts and tooling.
      charlotte
      Mini V8
      Im sure you already know this but Ijust have to say it, dude you are BRILLIANT.
      Chicago
      simply awesome
      okay why not build a little car to go around that motor.
      marty-mj
      Oct 2005
      Lima, Ohio
      Ha! How do you even do that?! Stewart Little can finally hotrod in a Chevy!! Thats amazing! It probably has more horsepower than my car too.
      have you ever thought about doing a full size engine?
      i have always thought it would be cool to do a v4 with a big block chevy (454) specs.....
      you could use alot of the already tested head designes, racing technology, pistons, rods, modify some aluminum heads.
      think 12,000 rpm, 3.5 liter screemer in a 1000 lb sand rail. or VW bug or motor cycle
      Aug 2006
      Hampton Roads, VA
      That is one of the most amazing things I have ever seen! You must have a lot of spare time.
      Do you think you could build one for me? I want to have the only R/C car around with a blown V8...
      1980 Pontiac Trans Am, Chevy Big Block 468, TKO 600 Trans, Hotchkis TVS, Bilsteins, Eaton/Motive 3:73's, 18" Coddington Junkyard Dogs, Nitto NT555 rubber, Autometers http://www.fquick.com/Bandit
      http://www.cardomain.com/ride/2458763
      Jul 2002
      Mesquite, TX
      Is this yours, or just a website you found?
      Ontario, Canada
      Where's the video!?
      Ken
      My other car is a Vega.
      Shelby Twp./EL, MI
      Quote Originally Posted by derekf
      Website I found...
      but thanks to everyone who said I was brilliant, you may continue doing so
