    Results 41 to 60 of 67
    1. #41
      Ok your defending your self. So leave me and my design out of it. Take it outside.
    2. #42
      Quote Originally Posted by LowBuckX
      Again I didnot ask your opinion.
      Ah, but you did. When anybody posts a "Look at what I did" thread, the implication is that all opinions, informed or not, are fair game.
      What are expressly disallowed are personal attacks. SatisTraction hasn't attacked anybody. He has expressed his doubts about your design, and has done it in a non-personal way. That's always fair game, and not only that, it's important that we allow it. It makes for good technical discussion, and lets the rest of the community learn something.
      jp
      ​John Parsons
    3. #43
      I dont care anymore I know most people hate my car on this site so I just will not post about it anymore.
    4. #44
      Jackson Ms
      actually i like your car and any budget build
      Chris V
      SOLD
    5. #45
      Nov 2001
      Sacramento Ca
      Not. I think your car is just as cool as any other here. And your doing it yourself and that's even harder core. If you stop posting about your work, lurkers will never learn anything except "take it to a shop"
      Tony Langlois
      1966 Corvair Monza
    6. #46
      Michigan
      I agree..... alot of people dont build their own cars... I like to see when people do it their self!
    7. #47
      Lees Summit, Missouri
      LowBuckX, don't get bent, your skin has to be thick, keep up the work and keep up doing it yourself that makes it the best part!! Even if you don't like what is said, it may make you look at it a different way, right/wrong/indifferent. At any rate, keep us posted on the progress.
      Later - Craig
      [email protected]
      '70 Chevelle (in storage now, probably will never be back on its wheels again!)
    8. #48
      I appreciate suggetions from people like Mr Pozzi and others who know what they are talking about I realy do.
      But it seems like if I dont do it exactly like others do or If someone else didnt do it for me Its wrong. I do have thick skin but you can only poke it so much before I get mad. I should not get pi$$ed about one person but he should know when to let it go too.
    9. #49
      its your car so dont worry about how the others would do it.i to am building my own and i did it my way.so keep it up and dont worry about the ney sayers.
    10. #50
      Aug 2005
      Hamilton, NJ
      You are wrong. Keep up the good work.
      Scott from NJ.
      Vent Windows Forever! ...
    11. #51
      Calgary, Alberta, Canada
      Quote Originally Posted by SatisTraction
      that yellow car that belongs to herb is NICE. it is also a TRACK car with a CAGE in it. I would also bet the body is mounted SOLID to the frame.
      Just a couple clarifications. The yellow car on the Hot Rod cover is indeed a race car - its Herb Adams VSE's entry into the 1981 Daytona 24 Hour Endurance race. You could literally order all of the parts for that car (a "Stage III Cheverra" intended for road racing), except the engine, out of the VSE catalog that year. It has a really impressive full roll cage which is tied to the subframe - and it doesn't have the cowl to fenderwell braces at all.
      However, the car that Herb entered in the Adams vs. Gulstrand shootout referred to on the same cover is a Stage II Cheverra intended for autocross. It has no rollcage, only a chrome Hooker 4 point roll bar, and it does have the cowl to upper control arm mount struts.
      Edit: One other thing - the VSE handbook says that the F-body subframe can deflect over 1/2 inch at the point reinforced by these struts - and the struts are intended to be used with solid subframe mounts, to eliminate that flex in combination.
      Steve
      1978 WS6-W72 4-speed Trans Am: Fire-Am Restification Project
      VSE front and rear sway bars, solid spherical control arm and spring eye bushings, front springs trimmed 1/2 coil, VSE aluminum oil pan and baffle; Pro-Touring F-Body solid aluminum subframe bushings, 1980 WS6 rear disk brake system, 12" 1LE front disk brakes, Alston cowl-to-subframe Y-braces and subframe connectors, Moser axles, Hooker chrome roll bar, Corbeau GT-8 seats.
      2000 WS6 Trans Am M6
    12. #52
      Miamisburg, Oh
      Yo LoBuckX, I like reading your DIY stuff man. Keep it up.
      Remember my recent post on basically the same subject? You posted in it....
      https://www.pro-touring.com/forum/sh...ad.php?t=27695
      I'll be trying to put similar bracing in my car and I will not have a cage. ;) I really dig ol' Herb Adams. Always have. Got a set of swaybars from him too!
    13. #53
      Den Helder, the Netherlands
      Country Flag: Netherlands
      Basically the same comments as BA, only I don't have the VSE swaybars . . . .
      Keep up the good work man, you are an inspiration to a lot of us (I'm sure).
    14. #54
      Central CA USA
      Quote Originally Posted by rb70383
      Any reason why they are attached to the UCA's? Would it be better if they were moved front more? Like to the bottom of the rad support, but still welded/bolted to the frame? I might see about doing this to my car. It has a front subframe that is removable, I imagine like Camaros? Dont beat on the Mopar guy So for attachment to the firewall, a plate inside that is also welded as well would help?
      One of Herb's methods was to use as many existing mounting points as possible. His parts were bolt-on as much as possible to make them.
      I agree some weld on brackets on the sub might be more convinient and possibly better locate the braces out of the way. I hate obstructions around the engine so these braces are a love/hate issue for me. I love the results, hate the extra tubes in the way.
      David
    15. #55
      Central CA USA
      i was gone until i read the bashing i was taking. I agree with the theory behind what you are trying to do. I just do not agree with the way you are doing it. You have not proved me wrong with your fabrication. Do you want to? Take a 0-100 pound fish scale and hook to the control arm bolt hole and pull it up. see how many pounds of force it takes to move the bars. I am not sure how much movement would be considered passing but i doubt the frame flexes more then 1/8" if it mounted solidly to the body.
      one thing that concerns me safety wise? how are you mounting it to the control arm bolt? are you using a second nut or the control arm nut? The single contol arm nut is not the best idea. It will pivot there and loosen the single nut. The control arm nut, followed by a washer, the channel, washer, and then a locking nut would be less likely to loosen.
      SatisTracton,
      I have some concerns about the firewall strength too, as far as long term durability, but it seems to work well, that's why I suggested some extra reinforcing, and wider plates. The braces don't carry ALL the load, just help carry PART of the load. Again the main "load" I think is important is torsional load. Would it be better if it were tied into a roll cage? Sure, but that isn't going to happen in this case.
      Here is where we have talked about firewall braces in the past:
      https://www.pro-touring.com/forum/showthread.php?t=4974
      https://www.pro-touring.com/forum/showthread.php?t=8510
    16. #56
      Quote Originally Posted by TonyL
      I be one of the lurkers
    17. #57
      California Bay Area
      I enjoy your threads also.Hotroding is all about inovations like yours.
      65 Impala
      01 Z06
    18. #58
      I wouldnt call anything I do inovation Its more of copying/molding to fit my budget. It involves more research than actual wrench time. Thats one other reason I get mad when people poopoo what i do. I copy 99% of it from these pages that everyone on this site contributes to. Nothing new just done in a way to fit my budget
    19. #59
      Nov 2001
      Sacramento Ca
      Don't read into it too much. Sadly the state of affairs in the magazine world has lead to one feature after another that reads like a advertisement for all the top shops and all the easy bolt on parts. New enthusiasts are born every minute of every day. They read those features, put two and two together and then find their way here. Armed with "that's how the magazine guy did it" everyone is an expert and everyone is SPOILED as to what a car should look like and what parts they think a car should compose of.
      It should be our responsibility to show what can be done with cobbled together parts gleaned from parts houses and junk yards, and the knowledge gleaned from the experienced racers among us to achieve the same performance and good looks those magazine cars have.
      If we dont, no one will. The days of mags running a "build it yourself with junkyard parts" days are over. They depend on the advertising money too much now. It's up to us to put cars like yours and mine against cars with name brand parts and name brand mods.
      Our hobby should never get to the "only the rich can do it right" attitude pro-street got to. If it does pro-touring as we know it will die.
      Keep doing what you are doing. Inspiring all those people who need to see that pro-touring can be done on a budget. And done well.
      Tony Langlois
      1966 Corvair Monza
    20. #60
      Central CA USA
      Tony, Well put!
      I have a soft spot in my heart for the "Little Guy".
      It might seem I'm pretty well-off because I have a vintage race Can-Am car. But when I bought it in 1974, I was 23 years old, married with a kid and driving a farm tractor for a living. I paid $600 for the Lola in wrecked condition. When I needed a larger rear antiroll bar I went down to the river where the land owners had used cable to tie old wrecked/pancaked cars to the banks to prevent erosion. I found a front antiroll bar on a Cadillac that was the right diameter, removed it and re bent the ends in the farm shop to fit the Lola. I raced with that bar for several years until I could afford to buy new material to make a better one.
      On my 67 Camaro around 1974 I made my own solid subframe mounts by finding some thick collars that were used to hold axle bearings on Ford type rear axles. My uncle had gotten a whole bucket of them from a shop in town and a couple of them per bolt worked just right. To make firmer lower control arm bushings I hammered headless nails into the rubber. got that tip from Hot Rod!
      LowBuckX keep it up!
      And don't get down if someone questions you or disagrees, it's GOING to happen. We get pretty long on theory here in the forums, but there is nothing like trying it and finding out for yourself.
      David
