      Morrisdale, PA
      clutch fork boot
      Do you need a rubber boot for where the clutch fork exits the McLeod bellhousing? Got one with the clutch pedal and linkage kit but it does not fit into the McLeod. Can I just leave it out?
      Dave
      Dave
      You don't really need it but if you would like to put one in, Lakewood makes one and I'm told it fits the McLeod housing.
      Aug 2006
      Hampton Roads, VA
      I was wondering the same thing. My Lakewood boot fit the bellhousing but the fork kept moving it out of place when put through its range of motion. So naturally I gave the boot the boot.
      Hasn't caused a problem in the 1,000 miles or so I have put on it. The only thing I am concerned about is that oil from my leaky engine doesn't get down onto my clutch...lol
      1980 Pontiac Trans Am, Chevy Big Block 468, TKO 600 Trans, Hotchkis TVS, Bilsteins, Eaton/Motive 3:73's, 18" Coddington Junkyard Dogs, Nitto NT555 rubber, Autometers http://www.fquick.com/Bandit
      http://www.cardomain.com/ride/2458763
      Delaware, OH
      Dave, I initially used the Lakewood boot with my bell, but since converting to the hydraulic clutch haven't used the boot. No problems so far.
      Morrisdale, PA
      Thanks guys. Sounds like no boot will be just fine then.
      Quote Originally Posted by NovaPwr
      True statement.
