    Results 41 to 60 of 62
    1. #41
      Quote Originally Posted by BonzoHansen
      Nope, I asked because I basically heard hearsay. Not even specifics. A guys yapping at a show. He said accessory mounting, but I'm betting it was just accessories themselves.
      The mounts (actual brackets) are different. Just like Corvette mounts are different from F-body mounts, from GTO mounts, from CTS-V mounts. There is no difference in the holes in the block or heads for the accessory mounts. For instance I will be using C5 accessory mounts on the 5.3L that I am building.
    2. #42
      Feb 2006
      Elk Ridge, Utah
      YEs I am referring to the L92 heads they are LS7 Toss outs and ended up on a 400 hp truck engine.
      The problem i see with the L92 heads is the EX flow is on the low side so I am going to Buck up and buy the LS7 heads at the last min . As Gm is also working on 6 bolt per cyl LSX heads to go with the LSX block
      This stuff Has the Professer Warren J behind it all for prostock class
      No they will NOT fit any 5.3 or 6.0
      Thats Why I said to buy the NEW performance block Bore and Stroke it to 427 or near 500 Ci on the CHEAP.
      The cost of a 572 and the weight is pointless with these new Super SB'S. The strength and reliabillity of a Gen3 is far greater....
      Gm STATES The New LSX block is good for2k HP +.....
      You can build a 500 Inch SB makin 700 + HP NA for shy of 10k.
      You just have to do your homework and that starts at LS1Tech.com
      If memory serves me right 5.3 is actually 325 cid not 327 it makes 327 Hp.
      My 4 door truck starts to break the tires loose in the middle of an intersection as I run for a yellow bone stock or as I accellerate onto the fwwy.
      I am very Impressed with the power of this lil engine
      EDIT: Wrong head Number info Srry
      69 Camaro
      W/D sub, Wilwood 13" brakes Bozeforged wheels 18X10 & 18X12,
      Lateral dynamics 3 link ( custom setup ) Dana 60
      lsX Twin Turbo, soon to come
      Viper T56 in place (Yay)
      Bought a running driving car so I can enjoy it before Im dead
      LD 3 Link Installed into ^^^^^ (Yay)
    3. #43
      Quote Originally Posted by Madspeed
      YEs I am referring to the LQ9 heads they are LS7 Toss outs and ended up on a 400 hp truck engine.....
      LQ9 heads are 317 heads and they fit a 5.3L just fine. You mean L92?
    4. #44
      California
      I hate you guys, I wanted to stroke my 350 to a 383 and then tubocharge it later.
      Now I can't make up my mind if I want to do that or get an LS motor.
      Matt
    5. #45
      Feb 2006
      BC Canada
      Quote Originally Posted by andrewb70
      Aren't they on both LQ9 and LQ4 ?
    6. #46
      Feb 2006
      Elk Ridge, Utah
      Ya Your right Andrew Im retarted
      Soory Folks ill fix that
      69 Camaro
    7. #47
      Feb 2006
      Elk Ridge, Utah
      Quote Originally Posted by DarkoNova
      Matt
      Matt You will notice I SOLD a 496 With a ton of good stuff just to start over from scratch with and LSX platform.
      I had a 4 Blt block Scat crank and Hbeam rods, JE custom 10.5:1 Pitsons, Zero gap rings setup for BIG shot o Squeeze (400 Hp +)
      Aluminum heads Merlin, Jessel Belt drive, BIG solid roller bumpstick,
      Victor intake and 1050 Dominator carb, + more it cost me upwards of 13k for machine work and parts.
      I dumped it for 6k, Wich took 9 months to sell (Nobody wants a BB anymore)
      69 Camaro
    8. #48
      Aug 2005
      Hamilton, NJ
      Thanks. I wanted to be set straight.
      Scott from NJ.
      Vent Windows Forever! ...
    9. #49
      Quote Originally Posted by 00fxd
      Yes Sir...
    10. #50
      Feb 2006
      BC Canada
      Is it a truck intake on the new all aluminum 6.0 [LS2?] in the trucks ?
    11. #51
      The new truck 6.0L, aluminum block is the L76, the 6.2L is an L92, also aluminum block. Both engines use a truck type intake.
    12. #52
      Springfield, Mo.
      Actually, there is a small difference in the way that the alternator will mount if you use the f-body accessories.
      I am not sure how the alt bracket mounts on the LS1 block, however with the 5.3 block you have to utilize an existing hole on the block for the lower mount, and then drill and tap a hole for the upper mount. it looks like the block was cast using the same cast b/c there is a place right where that hole should be, it just looks like the factory didnt drill it out.
      I just did this over the weekend, here are some pictures
      http://www.cardomain.com/ride/2163805/6
      1967 Camaro - Done!
      1968 Camaro - Underway
    13. #53
      Quote Originally Posted by TA219
      Wayne,
      Thanks for the info. It looks like you have an iron block 5.3L. I just compared you pictures to mine and the aluminum block 5.3L have the holes. Good info!
    14. #54
      Dunwoody, GA
      Not sure on the truck 6.0 but the trucks with the LS2 such as the trailblazer SS and the 05 SSr use the LS2 intake. haha now that GM is making the truck blocks in aluminum its going to really start gettng confusing. Guess we will have to learn the RPO codes for the new truck engines. First one I can think of is what the hell is an LS4?
      Trey
      ~ Jon Hammond
    15. #55
      Quote Originally Posted by WS6
      LS4=5.3L aluminum block engine found in the 05 and later front drive vehicles. Monte Carlo and clones. These have DoD. Displacement on Demand.
    16. #56
      Feb 2006
      BC Canada
      ........Which brings me to question that I have had for a while . Is the front wheel drive 5.3 block casting the same as the rear wheel drive engine block ? To rephrase , will these engines interchange ?
      Thanks , Frank .
    17. #57
      Thanks , Frank .
      Frank,
      I do believe that the blocks are the same. There are differences in engine mounts, exhaust manifolds, accessory drive, intake manifold, etc... However, the bare long block should be the same.
    18. #58
      Feb 2006
      BC Canada
      Frank,
      Thanks agian Andrew , what are you using a 5.3 in?
    19. #59
      Its the new engine for my new junk RX7.
    20. #60
      Socal, Ca
      Andrew,
      Does your motor have the DoD? What computer are you going to use with it?
