Thread: AWD kits
11-29-2004 #1
AWD kits
Is there any sites that sell AWD kits? I'm in the works of planning out a full frame for my bird and I always wanted a AWD muscle car.
If no kits are out there is there any parts I could use or any helpful links? Also any computer programs to design a frame would be nice. thanks
Also you could e-mail me if you have any suggestions-David
11-29-2004 #2
Full Blown G-Machiner
- Nov 2004
- Roanoke, VA
- 515
I dont know how serious you are about an AWD set up in an F body but us Syclone/Typhoon ppl have been using one since the vehicles rolled off the dealers lot. To answer your question I dont know of anyone that offers an even remotely bolt in-able AWD set up as it would take a tremendous amount of R&D to offer it for just one type of vehicle.
FWIW you may want to look into the Syclone, Typhoon, and Bravada as they share the same AWD driveline. Also everything is the same among those vehicles and the common S10 4wd trucks/SUVs except for the shiftable 4wd front diff and transfer case (that equals cheap driveline parts). The AWD transfer case is a viscous coupled unit that splits the torque 35/65% front and rear and is used in the syclone, typoon, bravada, and AWD astro van. The front diff is the same unit as the 4wd S trucks except for the pass side axle tube having the 2wd/4wd shift mechanism on regular S trucks. This is easily changed for use as an AWD unit by unbolting the regular 4wd axle tube and replacing it with the AWD unit. Thats the super quicky over view of AWD systems Im familiar with that I thought may fit with only a slightly huge amount of work.
Lots of info at www.syty.net forum if you want to kill some time.GMC Syclone (currently wrecked thanks to the typical rubber headed VA driver not paying attention to his red stop light...oh and he didnt have insurance either)
#614 11.9 @ 113
New stuff finished 08/06:
4L80E trans w/TCI PCM
Syclone
Tow rig
11-29-2004 #3Ya i didnt think that they made bolt on kits for f-bodys. I just figured they made some for hotrods. I know i seen hotrods with awd. Anyways thanks for the link. I do have time to kill
thanks again
-David
11-30-2004 #4
- Nov 2004
- Roanoke, VA
- 515
If youre talking about the Summit Quadra deuce(sp?) it uses a syclone transfer case and a few other components as well as custom front axles and suspension. My understanding is other than the xfer case and a few other do dads being syclone pieces the rest is hand fabricated. Dunno for sure as thats just what Ive read in the typical HRM/CC rags.
#614 11.9 @ 113
Syclone
Tow rig
11-30-2004 #5
