    Results 1 to 20 of 29
    Thread: Newbee 73 TA
      Lodi, Ca
      Newbee 73 TA
      I'm a newbee and will be looking for wisdom from all you pros as I do some more mods on my toy. Here's an overview of what I've got to start wGeneral:
      Year:1973
      Make:PONTIAC
      Model:TRANS AM
      Chassis:
      Front Suspension:Stock springs, KYB SHOCKS, POLY BUSHINGS
      Rear Suspension:Stock springs, KYB SHOCKS,POLY BUSHINGS
      Rear Axle:3:42
      Brakes:REAR DISK WS6
      Wheels & Tires:AR TTII,17" X 9.5 "FRNT & REAR, 285/40 REAR, 275/40 FRNT
      Misc:CE BOLT IN SUB-FRAME CONNECTORS, ALUMINUM BODY MOUNTS
      Paint & Body
      Color:WHITE, CLEAR/BASE
      Graphics:PHOENIX GRAPHICS
      Interior
      Seats:STOCK
      Upholstery:CUSTOM STOCK
      Carpet:STOCK
      Dash:INSTALLED FACTORY AC, NON AC CAR
      Gauges:STOCK
      Shifter:COMP PLUS
      Stereo System:ZAPCO & SONY, MEGA WATT! ADDED FACTORY PWR WINDOWS & DOOR LOCKS
      Engine & Transmission
      Type:455, .035, 530 HP, 570 FTLBS
      Camshaft:COMP CAM HYD ROLLER
      Cylinder Heads:EHEADS PORTED
      Valvetrain:HARLAND SHARP RR 1.5
      Induction:PERFORMER RPM, PORT MATCHED
      Exhaust Doug's Headers, Flowmaster American Thunder system
      Transmission:M21
      Cooling:BCOOL WITH 2-10" ELECTRIC FANS, push, stock fan ,pull
      ith.
      Michigan
      got any pics?
      1979 W72 Trans Am- original for now
      1996 Z28 A4- stock with an sts rear mount
      Lodi, Ca
      Here's a couple.
      Aug 2005
      Hamilton, NJ
      Scott from NJ.
      Vent Windows Forever! ...
      Lodi, Ca
      A couple more now that I've shrunken them!
      Jun 2006
      Man, I want one of those in a bad way. Me likey!
      I just sold my 73 project now after seeing this i regret it. Nice ride.
      1970 TA, 1963 Impala SS vert
      Feb 2002
      Bay Area CA
      But wheres the Tri-Y's? LMAO.
      -Ian
      1973 Formula 400
      LS1/T56/3.73's
      Daily Driven.
      May 2006
      Northern NJ
      What is the offset of those rims? How did you manage to fit 9.5 rims all the way around??!?! Bird looks real good. Nice power and torque numbers as well...
      1974 Pontiac Firebird Formula
      1971 Pontiac Firebird Formula Clone
      1973 Chevrolet Camaro
      Harriman, Tennessee
      Very Nice! Welcome!
      Shiny Side Up!
      Bill
      '72 442 "Inamorata"
      www.FQuick.com/ProTouring442
      "You can never go home again, Oatman...
      But I guess you can shop there."
      Lodi, Ca
      If I remember correctly they were 5" backspacing, could be 5.5", I'll have to check. Had the same size tires all four as in back originally, but went with a little smaller tire in front.
      Lodi, Ca
      Old school, you must be from the PY board also to know about that!!
      Feb 2002
      Bay Area CA
      Quote Originally Posted by 73ta
      Yep, FLYNLOW on that board. I'm going to have to come check your car out soemday, being Im in the area and all.
      -Ian
      1973 Formula 400
      LS1/T56/3.73's
      Daily Driven.
      Lodi, Ca
      Give me a holler, we have a local car meet at the A&W on Thurs. evenings. Bring your ride over in the spring!
      Feb 2002
      Bay Area CA
      Its driven year round!
      <----Me in the rain. LoL
      -Ian
      1973 Formula 400
      LS1/T56/3.73's
      Daily Driven.
      Montgomery, IL
      Welcome aboard 73. I think we all can move on from the Tri-Y fiasco. This is the first pics I have seen of you car from multiple views. Nice. Do you get any rubbing from the fronts? I would like to know the backspacing you are using up front.
      71 Formula, 455 SD/KRE D-Ports, Crower solid cam, TKO 600, 3:73 Eaton posi. 17" ARE 200s, , 1LE brakes, Koni, Rancho adjustable bars, Hotchkis springs
      Lodi, Ca
      Oldschool, they only have the car show spring thru fall, but come over anytime.
      Zee, backspace is 5.5" front and back. Tires might rub if I drove it hard, autocross, but I haven't done that yet. I just bought standard backspacing, wish I would have custom ordered it. Link I posted in the wheel & tire section says to use 6" backspacing in front. Check ou that article.
      1973 TA G Machine
      2000 BMW 540 G Sedan
      Aug 2006
      Hampton Roads, VA
      Very nice-looking TA! Good job on keeping it looking stock while still upgrading where it counts!
      1980 Pontiac Trans Am, Chevy Big Block 468, TKO 600 Trans, Hotchkis TVS, Bilsteins, Eaton/Motive 3:73's, 18" Coddington Junkyard Dogs, Nitto NT555 rubber, Autometers http://www.fquick.com/Bandit
      http://www.cardomain.com/ride/2458763
      Lodi, Ca
      Thanks Bandit. I'll be looking for some feedback later when I look to upgrade the front suspension some more & I would love to have that TKO600 in mine also!
      1973 TA G Machine
      Near Cleveland, ohio
      Nice ride, I have a 70 T/A
