      Hackettstown, NJ
      Need input from t56 owners
      I'm trying to figure what gear ratios to put in a t56 that i plan on building. I did some caculation with 3.42 gear and 28" tall tire and arived at some prettty high speeds like 297 mph at 6000 rpm in 6th gear with .50 overdrive. kinda of a waste to me. wondering what current owner think of as well as how much that use thier 5th and 6th gears. seems like the .62 6th gear is that one to get.
      also dont want a rear gear to low so that first gear is wasted. that calaculations showed that at 2000 rpm in 6th gear was 100mph, so i would barely be able to use it except if I wanted to "cruise" the silver state classic.
      also , for those of you that have a g-force setup such as gears , shaft , ect, how noisy is it? heard it was quite noisy for the street? is it noisier than a ST-10?
      shoot me your expierences poeple. thanx
      6th gear in a T56 is designed for nothing more than dropping RMP to cruise on the highway. A .5 gear is very weak and it is not recommended to transfer a great deal of torque through it. There are other ugly things that happen with a .5 gear for top speed runs (like driveshaft critical speed) but we won't get into that here. Start focusing on 5th gear as your practical gear for top speed. 4.10s will take you to 176 in 5th at 6500 RPM, and allow you to cruise at 1850 RPM in 6th gear at 75MPH. I might even consider 4.30s depending on your engine and how happy it is cruising at 1850RPM.
      What kind of car? Engine?
      As for G-Force noise, I have no experience with those transmissions.
