    Results 1 to 9 of 9
      RI
      Header and exhaust size
      Now that winter is here and my car is in storage I'm making a list of things to do next year. I think my exhaust system isn't to great. Right now I have 1 5/8 dynomax headers (were coated but they rusted through so I painted them black.) My exhaust is 2 1/2" tubing with a kink on each side then flowmaster 40 series mufflers to 2 1/2" over the rear end then 3" tips that hang lower than the rear quater. I was thinking that i could at least use a x-pipe, or go all out and get 1 3/4 doug's headers coated with magnaflow system (not sure on 2 1/2" or 3".) The engine is a 388 chevy with 10.8:1 cr, gm 2.02 heads, z-28 intake dual plane, 750 holley, and cam with 507 lift 235 duration @ 50 and 108 lobe seperation. I dyno'd the car it made 318rwhp and 315rwtq corrected. I also have run 12.9 at 106 in the 1/4. What do you guys think? Thanks in advance.
      Frank M
      1970 lemans sport
      2005 srt-10 ram
      http://www.youtube.com/watch?v=SER1gBLn2N0
      RI
      No opinions?
      Frank M
      1970 lemans sport
      2005 srt-10 ram
      The 3" system for sure, unless you want to quiet it down for some reason but the x-pipe will also do that.
      RI
      Thanks, I'm going to change my rockers also to 1.65, so should change lift to around .557. I was thinking 3" anyway because I'll proberly upgrade my engine in the future. I'm also going to get the 1-3/4 headers too.
      Frank M
      1970 lemans sport
      2005 srt-10 ram
      Dual 3 inch pipes is WAY overkill for your power level. Unless you want to spend money and not gain anything, what you have will carry you a long way before it becomes a restriction.
      Fontana, CA
      Agreed. Bigger is not always better and in your case is overkill.
      Nick R.
      RI
      So 2-1/2 magnaflow system will be better than my crappy kinked exhaust with flowmasters? So 3" is not needed and will have no power gain? My wallet is happier now.
      Frank M
      1970 lemans sport
      2005 srt-10 ram
      Fontana, CA
      The Magnaflow will do better and the 3" will not only be useless, but may hurt low end power. happy wallets rejoice!
      Nick R.
      florida
      exhaust?
      thats kind of the system im looking to do with an ls1.2.5 with x member and magna flows.how do the magna flows sound?how do they compare with quieter flow masters?never have heard them.justy read that they flow pretty good.
