    Results 1 to 13 of 13
      Oct 2006
      t56 reverse lockout solenoid
      the only thing we've came up with so far is to use a shift knob with a button on it to trigger it, but i don't think it looks good, plus, there's a wire coming down from it
      any other solutions out there?
      for a 65 stang, and we definitely need it with the shifter we have because basically, it's impossible to get into reverse without it
      Quote Originally Posted by absolom
      You can also wire it to the brake light switch.
      Oct 2006
      Quote Originally Posted by andrewb70
      we thought about that, but that solenoid would be going crazy, i really don't think it would be good to have it trigger that much
      Why not? It’s just on or off. I am sure these solenoids were tested at duty cycles WAY beyond what you’re going to subject it to. You can actually shift into reverse without power to the solenoid as well. It will go in.
      Oct 2006
      we were gonna not use it, but with the style shifter we have, it's almost impossible to get into reverse without the solenoid being off
      Feb 2004
      Paris, Illinois
      If you think about how they work from the factory, it's really not that much different. They disengage when your speed drops below 5 MPH. You might hit the brakes more than you slow to a stop, but I don't think it would be that much different.
      Michael
      1969 Camaro
      CamaroHeaven.org
      fQuick Garage: http://www.fquick.com/Overkill
      central valley CA
      I have pics on how to bypass the solenoid completely. Mechanical instead of electrical. Mike
      Oct 2006
      Quote Originally Posted by protour70
      but does it have a trigger?
      at first, we took the solenoid out, falsely thinking that without it, it was still "triggered"
      so we had it out, and discovered it was wayyyy to easy to put into reverse, so we put it back in, and we were just gonna leave it on all the time, but then we changed shifters, and it's very hard to put in reverse
      could you post the pics anyways though?
      thanks
      Eastern Virginia
      From the factory, the PCM energises that solenoid anytime the vehicle is going less than 5mph. So anytime you are at a stop light it is open. I think it would be fine to energise it with the brake. On mine, it is connected to the PCM just like the factory, but if I try I can still get it into reverse. Basically you can over ride it if needed. I debated not connecting it at all & just force it into reverse. I say "force" but it isn't that tough.
      Scot
      86 Monte SS
      Oct 2006
      i think we're gonna use the original headlight bright switch on the floor
      Jun 2005
      Bethalto, IL
      I cut removed the solenoid from mine and rearranged the other mechanical parts to make reverse require a fair amount of pressure to get into.
      central valley CA
      Email me and Ill send the pics
      Eastern Virginia
      It will go into reverse with some force as is.
      Scot
      86 Monte SS
