      Eastern Virginia
      Engine ID number decoding?
      A friend of mine at work has sent me the following asking if I know anything about it. I don't, but thought maybe someone here would. Thanks
      The number begins "D00FI..." I can't remember the rest at this moment.
      I just remembered that I needed to find out what it was. Anyway, the "D00"
      is in a larger stamp than the remainder of the number. I have never seen an
      id like this so it has me wondering. Any help is appreciated.
      Scot
      86 Monte SS
      Lees Summit, Missouri
      Who's engine, Chevy, B-O-P???
      Later - Craig
      [email protected]
      '70 Chevelle (in storage now, probably will never be back on its wheels again!)
      Eastern Virginia
      Sorry, it is a Chevrolet. It is a 327, but not sure the year.
      Scot
      86 Monte SS
      That number looks like the start to a partial Engine Code, here is how a true stock block engine code would look:
      example: T0414DM
      T = Tonawanda, New York (plant where manufacturered)
      04 = April (assy month)(57-59 models had either 1 or 2 digits for the month, however, starting in '60, they went to 2 digits for all)
      14 = 14th (assy day)
      DM = actual engine suffix (in this case, it shows this engine was a 283 paired with a Powerglide trans, a/c, 4 bbl, 230 hp)
      I do not, nor can I find any reference to the characters you have listed. Can he find an actual casting number on the block?? (all numbers)
      Later - Craig
      [email protected]
      USA
      Get the number off the back of the block , located on the drivers side rear.
      ( Which is the bare block casting # )
      AND the number / suffix off the front , located on the flat pad in front of the passenger side head. ( which actually determines what the engine really became )
      Jeff Tate
      U.S.A.
      Dec 2000
      NE Florida
      GM skipped zero's and O's in engine code sequences, for fear of confusing the two. The common spots to find #s are:
      1. The right front pad of the cylinder deck (above the water pump port). These normally die on the first visit to a machine shop.
      2. The block casting #s on the driver's side rear, TOP (to the left of where the distributor hole is, looking forward)
      3. The cast # of a block- i,e; a "010" block, which is the high-nickle block. This alone will NOT ID a block's CID.
      post your #s and I can use my Hollander to find it.
      Eastern Virginia
      He was going to get the numbers tonight. So if I get them tomorrow I will post them.
      Scot
      Scot
      86 Monte SS
      Nov 2004
      Sweden
      Country Flag: Sweden
      Suffix Codes
      Hi!
      Try this one...
      http://www.chevymania.com/
      "PARTS ID"........
      "SUFFIX CODES" ,...Left corner.
      "Osdmike"
