    Results 1 to 20 of 24
    Thread: LS7 Controler
      LS7 Controler
      I'm considering a LS7 with a Katech torqer cam, ATS headers. Any suggestions on a controller.
      Have a look at FAST. I'm told their eDIST2 will support the LS7 crank sensor.
      jp
      ​John Parsons
      Controllers
      jp
      Has anyone you know used this?
      I am trying to find options on controller. Or is the stock one the best to go with.
      Oct 2006
      Stillwater Oklahoma
      I have heard of people changing to an LS2 crank sensor and going with an LS2 computer.
      I spoke with Ron Wiggins (FAST tech support) about it last summer. He said it would be out "soon". I don't know if it's available yet. Have a look here.
      Actually, you'll have to change the crank reluctor wheel (which can be done), not the sensor. But yes, that will work.
      jp
      ​John Parsons
      SouthTX
      www.speartech.com already has the oem stand alone factory harness, ecm, and drive by wire throttle assembly for the 58x LS7. You can tune it for mods with HP Tuners if you like.
      Dec 2002
      Lost Wages, Nevada
      Dont screw around..... get the UMI Delphi 4B unit. In reality, it is the only thing to use.
      It doesnt require changing the crankshaft reluctor and has a much, much... better windows interface. It is also much more tunable than any other EFI system that I have seen... and........ it is what Katech uses for their LS7 systems. Basically, its a no-brainer.
      UMI has a factory stock tune and a slightly tweaked tune for the LS7. The tweak, on a bone factory stock LS7 makes 550hp with no mods or additional part changes from being factory OE. Not to mention that Caleb/Jason @ Katech already have a tune for the LS7 with their torqer camshaft utilizing the UMI 4B system
      It is also much better priced than all previously mentioned systems.
      Hey, got a link?
      jp
      ​John Parsons
      Oct 2003
      Arvada, Co
      JP,
      www.umiracing.com for some reason I could not copy the link to the page, but scroll over the truck in the banner and then on that drop down menu go to engine electronics.
      That is the system I am going with on my LS2
      Brian
      Quote Originally Posted by chicane67
      http://www.umiracing.com/gallery/Images/Catalog.pdf
      Dec 2002
      Lost Wages, Nevada
      Go Andrew... Go Andrew... Go Andrew...
      Sorry... for some reason I couldnt upload the PDF last night.
      The PDF is a little short on the feature descriptions. I wonder if they have things like ignition cut for shifting…
      north central Iowa
      Quote Originally Posted by andrewb70
      for that faceplated tranny....for full throttle clutchless upshifts
      Quote Originally Posted by justanova
      Yes Sir!
      May 2001
      Mesa, Az.
      We are very happy with our UMI Computer.
      Quote Originally Posted by PhillipM
      Phillip,
      Would you mind elaborating more on that? How is the drivalbility? HOw is the tuning process? Does the UMI computer offer the same level of detail as the OEM computer?
      Nov 2004
      Colorado
      Does UMI sell software to program it?
      Quote Originally Posted by EFI69Cam
      Read the PDF. The UMI system includes the computer, wiring and software. I would like to know more about the features since there isn't much in the way of explanation.
      May 2001
      Mesa, Az.
      As for tuneability what exactly are you wanting to know? I think that would be a better way to go instead of me trying to tell all that you can tune. Are there any certain things that you want to make sure that you can tune?
      May 2001
      Mesa, Az.
      Sorry I just saw your other post. I will look and see if that is something that can be done.
