    Results 1 to 12 of 12
      Windham, NH
      Help Me Narrow My Options
      Here's what I have:
      Car: '69 Firebird totally disasembled...purchased as a "project car" that was mostly disassembled.
      Front end: Just purchased GW upper and lower control arms with QA1 coilovers. Car came with what appears to be a conversion to a stock disk brake setup...but I know from the PHS docs that it did not leave the factory with disk brakes.
      Rear: Ford 9" with factory disk brake setup (not sure what it came out of). Detroit locker, N case with 3.89 gears (planning on switching to 3.55). The rearend and locker came with the car (not installed).
      Wheels: Will be 17" front and 17" or 18" in the rear. Style not chosen yet.
      I would like to upgrade to an aftermarket brake kit (SSBC, Baer, Wilwood?) for the front and rear. The car will primarily be a street cruiser. My budget is in the "sport" Baer/Wilwood price range.
      Any recommendations on front and rear brake "kits?" I am trying to keep this relatively simple.
      Thanks for your input,
      Phil
      Build site: www.73camarobuild.com
      Business: www.classiccarblasting.com
      Like us on Facebook!
      Indianapolis, Indiana
      brake options?
      For the money I would say Touring classics. Do a search here and you will find several people that have their kits. They use readily avalible GM parts, and the customer service seems to be good. As for the rear, I would look at an explorer disc set-up, or a bear serious street. Both would be an improvement over stock drums.
      Ben Mowery
      67 Firebird -Powered by Pontiac w/ RAM AIR V.
      Southern Indiana
      Actually
      On a ford rear the later model Exploder (Explorer) disc brakes set up works good from what i heard and does fit most 9in. Not sure but all you may have to do is whip up a set of brackets and mod some E brake cables.
      Good Luck
      Lee Abel
      AFTERMARKET PERFORMANCE
      Windham, NH
      I ended up deciding on the Wilwood kit # 140-2285BD and ordered today:
      Anyone else using this kit?
      Phil
      Oct 2006
      Ottawa, Ontario, Canada
      Just a heads up...the Wilwood kit is on sale @ Jegs....Pro Street kit #140-7582 for a 9" Ford
      http://www.jegs.com/webapp/wcs/store...tegoryId=22991
      '69 Firebird Twin Turbo SBC 400" Blow-through
      9.80 @ 141 w/ 1.88 60-ft..... on 17's
      9.21 @ 153 w/ 1.45 60-ft..... on PUMP GAS
      8.60 @ 164 w/ 1.46 60-ft..... on RACE GAS
      Windham, NH
      Quote Originally Posted by Stroked-Z
      Thanks! Now I just need to identify which Ford 9" it is.
      Phil
      i got the wilwood on my 9" and they look great
      Windham, NH
      Installed "most" of the kit on the front today.
      However, I ran into a "snag" on step #1. The bottom bolt they show for the caliper bracket is 3" long for a 1" span???? I don't get it. If it wasn't for that 1 bolt it would be totally installed.
      Anyone run into this? What am I missing?
      Phil
      maybe they got a wrong bolt in the kit mine went on with no troubles,also on a 69 bird
      Windham, NH
      Quote Originally Posted by restomodbird69
      Hmmm. Do you have the disk brake spindles (I do)? Is the lower mounting hole smaller than the upper (mine is)?
      There is a shorter bolt included in the caliper bracket hardware package, but is the same diameter as the upper bolt (too big).
      There is a disclaimer that mentions having to enlarge the bottom hole on earlier model spindles. It makes me wonder about the spindles that I have. According to the PHS docs, my car did not come with disk brakes, so I know there was a conversion done.
      Thanks for your help,
      Phil
      Windham, NH
      Okay, this was my 2nd stupid question of the week.
      Got it figured out. The bottom hole isn't even threaded and I didn't have the 2nd piece of the spindle attached to the back.
      The 3" bolt passes through the front and back prortions of the spindle and gets a nut on the back.
      In my defense, this was not clear in the Wilwood assembly diagram.
      Phil
      no question is stupid,theses things happen when we are excited to install new parts
