      Louisiana
      Power Window Switch's In 68-69 Camaro Console
      Has anyone mounted their switch's in the seat belt hole in a 68-69 console? I have seen it somewhere before but can't find it now. I just put my electric life power windows in my camaro and I bought the smallest switch's I could find from Watsons streetworks. I just havn't come up with the best way to mount them in that square hole in the console yet. Any idea's? Pictures?
      Chris
      El Dorado Hills, CA
      I did it in my car. I just changed my console though so my sites pics are of the new console. I have a pic of the ols console with the window switches in it. I will post it when I get home tomorrow.....
      Brad
      68 Camaro - Procharged LQ4 coming - Currie 9" narrowed, bagged, lays frame, BMW projector HID's LED tails, 18"s, lexus center console, seat warmers, A/C... Mini-tubbing in progress!!
      07 BMW 750li -loaded
      Louisiana
      Thanks....I would like to see some pics. I started making a plate to cover up the slot. I am going to weld some threaded rod to the bottom of it and bolt it down from undernethe. My rocker switches will bolt in to the plate. Both switches are mounted in an aluminum base that will stick up about 3/16". I was going to use some bondo to blend it in but still be able to remove it if nessesary, then paint it to match the console. Is this similar to how you did it?
      thanks,
      Chris
      El Dorado Hills, CA
      I used a piece of ABS plastic with the same look as the stock console. Kinda rough looking not smooth and a matte finish, heated it up a little so it was a curved and the inserted the "CAMARO" emblem between the 2 window switches. Sorry, been away from the computer until today. I will get the pics up tonight....
      Brad
      El Dorado Hills, CA
      This was one of the best pictures I could find...
      Brad
      Louisiana
      Thanks for the pics. Here are a few pics of what I have done so for. It is coming out nice so for. A little paint and get the wiring run. Thanks for the help.
      Chris
