    Page 2 of 4 FirstFirst 1 2 3 4 LastLast
    Results 21 to 40 of 69
      Delaware, OH
      Quote Originally Posted by GMJim
      dhardison. I'd be careful with that 572. I have dynoed three of these engines right out of the box and the weekest one made 670 hp. and 680 lbs of torque. That will break a tranny pretty quick if you can hook it up.
      Hope this helps a little.
      Jim, thank you for an EXCELLENT explanation. As mentioned, the demise of my TKO-I was indeed a high-torque engine, slicks and a stick track.
      As far as the 572, well, as long as I have the TKO I'm done with track time. It's just too darn expensive to replace TKOs between rounds.
      Apr 2002
      Thanks for the links.
      I looked at at Tremec ad in a cuurent Hot Rod and looked up a local vendor (they are known for good T56 upgrades):
      http://ddperformance.com/3550tko_parts__upgrades.htm
      I noticed:
      TG12---3rd Gear,4615(OPS)---3550/TKO. Upgrade from 8620 to super alloy 4615.---$299---Use with TG13
      TG13---3rd Gear,4615(OPS)---3550/TKO. Use with TG12.---$199
      Another $500 option. Funny how they offer a special 3rd gear huh?
      edit: another vendor I know of who sells TKO's is http://www.libertysgears.com/services.htm
      I've read of "FACE-PLATING" on T56's over at LS1tech.com seems to be a good bang for the buck to keep those alive.
      --JMarsa
      Quote Originally Posted by JMarsa
      --JMarsa
      For the record, the face plating does not improve strength. It eliminates the synchros and turns a TKO or a T56 into a "dog Ring" box. I have a face plated T56 in my RX7 from Liberty's.
      May 2002
      Northern California
      Yeah when I read this I immediately thought about Dan's Trem. Put this out at a bunch of different boards and maybe we can get some others that are having the same problem. could be a bad batch of gears?
      Vegas, its not a bad trans, I personally haven't heard of any problems and I do own one but its not runnig yet. I'd like to see if there is a possible problem with the 3rd gear forging. Try and get ahead of a possible problem.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Keisler Engineering has NEVER turned away a legitimate warranty claim, even when the transmission was outside the time limits of the warranty. Those here who know us and are not just here to dogpile us will vouch for that. This case is no exception.
      In this particular case, the customer abused the transmission, sent us a false statement as to the use of the transmission when it failed, and changed his story when Tremec got involved. His story went from cruising at 55mph to power shifting into 3rd at the strip. Simply put, Mr. Detranova missed a shift and engaged the gear only halfway when he released the clutch, causing the gear teeth to fail.
      As an authorized Tremec Warranty and Repair Center we have on-staff engineers and builders who are qualified to determine transmission use and failure. We also have at our disposal the vast knowledge of the Tremec tech team. Tremec and Keisler Engineers took a hard look at this failure and both determined that it was customer abuse that caused the failure.
      This in no different than running your new crate engine to 12,000rpms and crying for coverage when it melts down.
      This customer also joined every forum he could find simply to try to muscle us into fixing something he broke through abuse. We have over 4000 Tremec TKO transmissions in service, many in very high powered applications and most being stop light or drag strip raced. This is a testament to the strength of the TKO that has nothing to do with Keisler Engineering. Fess up Mr. Detranova, you broke it and now you want someone else to pay for your mistake.
      Finally, it is posts like these that mislead and start firestorms under false pretenses that are ruining constructive discussion on the forums. In a political and consumer culture where folks have a great deal of difficulty taking responsibility for their own actions it would be great if we could keep the forums clean and dedicated to the discussion of the hobby we all love.
      Keisler Engineering is proud to be the largest distributor of Tremec Transmissions and we will continue to serve the hobby to the best of our ability. Contact us directly if you want more facts about the transmission and our systems.
      I am gonna play devils advocate here and use a quote from the last message..
      "Those here who know us and are not just here to dogpile us will vouch for that. This case is no exception"
      Ok so lets here from "those here who know us" ANYONE WANT TO STEP UP AND VALIDATE KEISLERS CLAIM??? BUELLER??....BUELLER?
      Why do I get a vision of crickets chirping in the background??
      Aug 2006
      Hampton Roads, VA
      Quote Originally Posted by toofun
      This is an important thread, and I think cool heads, fairness and facts should dictate our responses, not our mud-slinging abilities.
      First off, I don't believe this thread is really fair to Keisler Engineering, since this site represents Classic Chevy 5 Speed much more than Keisler, whether officially or through word-of-mouth. Look over to the right of your screen, CC5S are official sponsors on this site, not Keisler. And guys from CC5S are always right there to answer the "which tranny kit should I buy" threads. Which is perfectly OK, they paid to be here. No surprise, then, that many here buy through them. My point is, a lot of the satisfied customers from Keisler are not here to give their inputs. Due to the tiny number of Keisler customers on this forum, you are not likely to get much of a response from guys who have had warranty work done through them.
      I have not had any problems with Keisler. Again, to be fair, I have not had much experience, but I have ordered and received help installing a transmission through them, and from my experience they seem like a good company.
      Shipping issues: non-existent, I got it all in a couple weeks. My driveshaft took a little over a week to build, just like advertised.
      As far as product, everything was well-packaged, and all the parts were as advertised.
      Parts: I was especially impressed with their custom crossmember, it was the best I had seen in any kit. The driveshaft looks like a quality piece, fit perfectly, no problems there. The kit was complete in every way, except for a missing o-ring for the speedo gear plug, no biggy.
      I was especially thankful for their good tech support since I installed my transmission 6,000 miles from the states and it was imperative that I had good support. I spoke with Richard and Gene from there several times, each time I called they were readily available. I sensed that they had a lot going on, but even though I had some stupid questions in retrospect, they were very patient and stayed on the phone until I was satisfied with their answer.
      In short, I would not be afraid to call them about warranty work. Again, I cannot say that I ever have had warranty work done through them, but then again, probably 99% of their customers never have either, since they are out quietly enjoying their trannies. All of my good experiences with them combined make it difficult for me to believe that they would simply blow me off if I came to them for warranty repair.
      Common sense tells me there is something fishy about this case, I just don't see why this one low-powered car blew the trans, while many others live on happily behind cars with sick amounts of power that are drag raced regularly. Maybe that's what happened, it just doesn't seem likely.
      I'm sure this post will make me some new enemies, but that is not my intent at all. If I find out that Keisler is a bunch of crooks then I will happily proclaim it. After all I am not paid by them or anything. I also want to be clear that I am NOT bashing Classic Chevy 5 speed, word on the street is you have great company, maybe as good or better than Keisler. It's just that buying a high-dollar item like a tranny is an important decision for many people and they should have the facts. Unfortunately I don't know all the facts in this case, but I would hope the truth comes out in the end, and I hope a good company doesn't get smeared through misrepresentation.
      Paul
      1980 Pontiac Trans Am, Chevy Big Block 468, TKO 600 Trans, Hotchkis TVS, Bilsteins, Eaton/Motive 3:73's, 18" Coddington Junkyard Dogs, Nitto NT555 rubber, Autometers http://www.fquick.com/Bandit
      http://www.cardomain.com/ride/2458763
      Fontana, CA
      Quote Originally Posted by keislerNick
      Since this apears to be anobvious backlash to this post in particular, I will ask you to da a search on all threads where a TKO and the name Keisler exist. You will find MANY dissatisfied customers based either from the CS, Sales or Warranty perspective. In my years of viewing and being a participating member here and Lat-g, I have maybe once heard praise for your shop, Several indiffernces and MANY complaints. Customer service being the greatest category for which complaints are noted. You state he joined every forum to complain, if you were on your CS game you would have signed up long ago to address the same conceerns from the beginning. Apparently you too are guilty of the smear campaign!! The internet and these forums are exactly the place to discuss all aspects of the hobby, including experiences with different vendors, good bad or indifferent. Since you feel a need to defend yourself, first follow my above advice and see how many people have had less than expected interactions with Keisler.
      When I go to buy my TKO I will go to CC5S!! They have no issue not only offering great service to their customers, but YOURS AS WELL!!
      Nick R.
      Oct 2006
      J -
      Thanks very much for the links. But, according to my Keisler invoice for the tranny, I already had the 4615 Chromemoly gearset in it.
      I checked out the links - very good info. Thanks
      Apr 2002
      Andrew,
      So the primary reason is to face plate is eliminate syncros so you can power shift without using the clutch?
      --JMarsa
      Andrew,
      --JMarsa
      You still have to use the clutch. It just makes power shifting much easier because the window of engagement is enlarged as compared to synchros. By using the clutch I mean you have to graze it, barely take the pressure off the input shaft. Full release on my clutch is about a 5-6 inch stroke of the pedal past the point of taking up the free play. For powershifting only about 2-3 inches of pedal travel is required.
      I have a long thread on ls1tech.com that details my experience. Search my usrer name and "Liberty's"
      The MT ET Street Radial is a very unforgiving tire. The sidewalls are very stiff and the compound sticky. This makes it very hard on parts. A drag slick or even a bias ply ET street will be much gentler on the driveline.
      NJ
      I know we're on the subject of 5 speeds here, but I remember reading in magazines that Rockland Star gear, or standard gear makes a 6 speed that will handle 1200HP. It was called Tranzilla. Is that true? How do they do it? Whats the cost and can the same ideas be applied to the 5 speed?
      Quote Originally Posted by protouring72
      John,
      Rockland as well as other companies can build a T56 with a 9310 gearset from G-Force. G-Force is the only comapny that I am aware of that currently makes gears for the T56. Rumor has it that Liberty's will be showing a straight gear set w/ dog rings at PRI.
      Oct 2006
      Just an update: Over a week later, I am still waiting for a response from Tremec after e-mailing 8 pics and history of what happened. I think I will call if I don't hear from them by end of week.
      Also, I took the 3rd gear to a tool and die manufacturing co. and they Rockwell tested the gear. It was 60-60.5 which he said was very very hard. He told me a metal file was just about 65 which has to be extremely hard. I guess being that it was a Chromemoly gearset, it should be. I know now that it is very hard, but I don't know if it was too brittle. I might try to find a metalurgist to see if he could tell me something.
      I am also concerned with the meshing of the gears. I don't know if they actually messed properly. I look at 2nd gear and don't like the wear pattern at all (although it is very slight - very low miles). when I reassemble it, I will put gear paint on all gears to see the mesh pattern (just like they do when they set up rear ends. That will tell the story.
      Anyway, thanks for all your comments and thoughts and I will keep you updated.
      Jun 2006
      I was thinking of getting a TKO600, but now im scared...should I be? I have a Doug Nash street 5 speed now, and have never had a prob...and the tko is stonger?
      Maybe its just some bad ones...I hope so. I dont drag race all that much, so maybe I dont need to worry. But I dont want to be freaking out @ the track! I want the overdrive, but not the probs. Anyone want to reasure me the TKO600 is still a great trans?
      Thanks guys.
      Oct 2006
      NJ
      This is a very interesting post. I agree w/ the above, IMO the choice of clutch is probably the primary culprit.
      When we build our serious duty automatics, we have some slip built in to save the hard parts. It's a wear item that is required to keep them alive to help cushion the dynamic load. It the part is inferior, it will break regardless due to it not being able to handle the static load which follows the dynamic load.
      Consider swapping to a less agressive clutch, this may eliminate the problem and allow you to run. It won't last as long but, will definatly help against breakage.
      FYI, I just installed a TKO600 behind my twin 76mm turbo'd 555 BBC in a 3800lb 55 Chevy. I dyno'd the first one I built w/ twin 71's last week and it made 1270hp and 1240ft/lbs on pump gas
      I'm in the exact situation. 95% street duty w/ 2-3 runs/yr at the races. I have the Sachs clutch that came w/ my Keisler kit and expect it to be the weak link before the trans takes a hit. Clutches are cheaper to replace! After that, I'll likely try something adjustable from RAM or McCleod.
      Dennis
      Moore Racecraft
      May 2002
      Northern California
      Again its not a bad trans, several factors as stated above can come into play. I have spoke to several people that have had failures in Tremecs and all where in the 3rd gear, with 2 where both 3rd and 4th failed.
      If you want your trans to last maybe look into getting some parts changed. I think most trans vendors can accommodate.
      Apr 2002
      It seems like there are more aftermarket gearset options for a T56. I think I'm leaning towards the 6 speed given the aftermarket choices.
      --JMarsa
      Miamisburg, Oh
      A few people have wondered about the reasoning behind 3rd gear failing (or and sometimes 4th), and why 1st and 2nd gears weren't the ones to break.
      Jim G eluded to this a little bit in his post but I wanted specifically point out that the 'load' experienced by the 3rd and 4th gearsets is actually much greater than it would be in 1st or 2nd.
