      which drop spindle?
      im wanting to get a set of drop spindles for my 67 camaro for the ride height & also to convert from drums to disk . what should i look out for ? theres so many on the market !?!?! im on a tight budget so any help would be greatly appreciated. thanks
      Houston,TX
      A quick search w/ the search feature will net you all the answers your looking for and more........
      71' Nova - LY6, T56
      Fontana, CA
      Quote Originally Posted by NvrDun71
      Correct. And they basically all say DON'T DO IT!!
      Nick R.
      Central CA USA
      Oct 2003
      Arvada, Co
      Did not even need to search. It is a sticky on this forum. The only dropped spindle you should even consider is the one from ATS.
      Brian
      Dec 2002
      Lost Wages, Nevada
      Ats.........
      ok guys thanks !! it looks like ill go with the drop springs for now . now ill have to figure out what to do for front disc ???
      Quote Originally Posted by bodyman
      The ATS spindles will give you superior suspension geometry as well as allowing you to install C5 Corvette brakes on your car. Problem solved.
      http://www.t56kit.com/
