    Results 1 to 14 of 14
      Colorado
      LS2 Accessory help
      I am in the process of buying a crate LS2 motor. Will the accessory serpentine system work off an LS1 f-body? I dont plan on running AC, just alt. and P.S. What about a serpentine off the 5.3 and 6.0 trucks.
      68 Camaro
      LS2 6speed
      Complete Hotchkis front and rear suspension, Global west SFC, 3rd gen steering box, C5 front rear discs w/ 4th gen booster and MC. 8.5" posi rearend with 30 Spline 12 bolt axles.
      Jun 2006
      Indianapolis,IN
      no the ls1 access. wont work. the balancer and the water pump are differant, kid of like the chevy long water pump and short. ls1 are longer than the ls2. We are in the same boat. Billet Specialties tru trac will work of you chenge balancer and pump.But you cant run drive by wire with it alt.is in the way. There is another company called Synister products thats making a surp. sytem now.check with them or theres always S&P. Hope This Helps. Tim
      You owe yourself a phone call or web visit to Wegner Motorsports. They've got exactly what you're looking for (I think).
      Check out this cute little movie.
      http://www.wegnerautomotive2.com/movie_1-belt_v2.wmv
      jp
      ​John Parsons
      Aug 2001
      Wilton, CA. (Sacramento)
      jp
      No AC?!!!
      Jody
      Apr 2003
      chbg, pa
      I have F-Body acc on my LS2 and it all works fine!
      In fact I have a Fbody balancer , F body ac set up from S&P , F Body alt , LS2 GTO water pump and LS2 GTO powersteering pump
      So yes F Body acc will work on the LS2 !
      Apr 2003
      chbg, pa
      jp
      Just curious , but how is it any different or better than stock accesories? Besides looks I dont see a gain in anything. Unless packaging is a concern
      La La Land, CA
      Just wait until after SEMA, there is a new system coming out.
      Tyler
      Colorado
      My thought is I would like to run the stock f-body ls1 acc. simply because they are cheap and plentiful. While s&p and everyone makes nice kits they are expensive and I dont like the chrome look. I am more about function than looks. I am just not going to spend $2300 on a chrome serpentine system. If I can make a stock Ls1 system work it will function as well if not better and save me money to use for a performance gain instead of a little "bling" under the hood.
      68 Camaro
      LS2 6speed
      Apr 2003
      chbg, pa
      Quote Originally Posted by Midnight68
      Stock F body will work fine.
      Aug 2001
      Quote Originally Posted by datsbad
      Packaging is my concern with the turbos. Something like the front runner would be perfect, and it appears there will be one at or about SEMA, so that's my plan at this point.
      Plus I am not sure if there is a stock bolt on setup that allows A/C and clears the early frames. The only ones I've seen that might have the stuff hanging up real high which won't work for me.
      Jody
      Mountain View, CA
      In Steve's LS2 parts thing a month or two ago they showed a katech tensioner and mentioned a propensity for LSx motors to pitch belts at high RPM's. How prevalent is that condition?
      True T.
      My blog
      SouthTX
      Quote Originally Posted by Damn True
      I can't speak for others, but I've never had an issue in my 69 LSx Camaro.
      Its only prevalent if you actually drive your car hard. Every time I go to the drag strip I bring a 15mm wrench with me. I use it about every other pass. Is that prevalent? I should really get that Katech tensioner. They developed it for the C5R program.
      Jul 2003
      Anaheim Hills, CA
      Yep.. I'm running LS1 f-body stuff on my LS2.. I am running an ATI f-bod balancer and Mezeire water pump.
      The Katech tensioner is the best $$ you can spend..
      And the belt-toss deal only has to happen once to be a PITA..
      1968 Track Rat Camaro:
