      Dec 2002
      New York
      Install a temp gaue with no bung in tranny pan
      Is there a way to install an electronic temp sensor for a transmission - but not in the pan - no bung? Is there any way to do it in-line with the cooling lines?
      I installed mine using a T-fitting. The temp sensor screwed in using an adapter. Cost, about $30.
      Metamora, Illinois
      Apr 2002
      North Central Texas
      Quote Originally Posted by rocketrod
      This is what I planned on using also.
      Shannon
      Modo Innovations
      940-391-9002
      It is not that hard to add the bung to the pan. If you add a bung you will end up with a lot less points that can leek or fail and you do not need to mount any extra parts. It also adds a drain point if you do not have one already. Just my .02$. Randy
      Please see my PT Garage for more info on ProBell Camaro. 67 style,99 comfort, options and drive-ability with NASCAR Late Model suspension front and rear.https://www.pro-touring.com/forum/vb...?do=view&g=106
      Car Domain PG
      http://www.cardomain.com/ride/2565383
      Dec 2002
      New York
      That was my original intent - however the tranny shop that built my new tranny - forgot to put a bung in for me - which got me upset - really do want to take apart the new pan - and break the seal and redo - just want to get it in the car - reason why I was looking for another alternative to a welded bung.
      Thanks guys - that autometer part is exactly what I will need.
