      Wichita, KS
      Chevy Keyless Entry
      Does anyone know how to get the keyless system into learn mode on a 03 Tahoe?
      As I remember it was a combination of cycling the ignition switch and the door lock button.
      Dunwoody, GA
      The info is in the owners manual if you happen to have that laying around. You don't need a service manual. My formula required me to pull a fuse and cycle the ignition switch.
      Trey
      ~ Jon Hammond
      Wichita, KS
      Unfortunately my manual tells me I need to see the dealer.
      San Antonio, Tx
      hold the unlock botton on the door and cycle the ingition switch on-off-on-off and let go of the unlock botton and the locks should cycle, then hold the lock and unlock botton on the key fob untill either the horn churps or the door locks cycle then do the same with the other remote. remember to learn fob #1 first then #2 or your settings will be backwards.
      Instagram: CamaroAJ
