Results 1 to 20 of 31
08-18-2006 #1
Aerodynamics and drag coefficient
Just wondering if anyone has any info on aerodynamics.Since I doubt any of us has access to a wind tunnel (although knowing the people on this board,I could be wrong),I was just wondering about a few things that apply to real world cars.I've read a bit about drag coefficient and most of them give formulas and scientifical explanations that do nothing more than give me a bloody migrane.I realize it's all about frontal area,but I was just wondering a few thing applying to not only fuel ecomomy,but handling as well...
1.Does the drag coefficient change much,if at all,by lowering the car?
2.How much is it affected by chopping the top,channeling the body over the framerails?
3.How much is it affected by raking the windshield? (I realize it is affected by this but how much and how much rake is required to gain a noticable difference)
4.How much does the rake of the body affect it?I've heard that a 1 degree rake and no rear spoiler seems to be best for a '69 Camaro for example
5.How much do brake cooling ducts affect it?
6.I realize the grill opening adds to the drag coefficient,but how would someone overcome this?
7.What kind of upgrades to the cooling system wound be required to cool the engine if the grille opening size was reduced?
8.How much does an underbody tray affect it?
9.Does tire width play into it at all since most people are going for wider,and wider wheel/tire combos
10.Don't you just hate people like me that ask so many questions in one post
"There is no such thing as 'cheating'...it's called 'innovation'"
~Smokey Yunick
08-18-2006 #2
- Aug 2004
- Maine
- 594
Ooh! Fun topic!
I'm by no means an expert on such things, but I did a bit of reading up on this very subject during the design phase of my Datsun 240-Z project. The old Datsuns are anecdotally notorious for being bad aerodynamically. I found some old wind tunnel data on the 240-Z confirming this, indicating that the drag coefficient on a stock-bodied Z is .46!
1) I'm not sure if lowering the car in and of itself will change the drag coefficient much. However, since the underside of most cars is not flat, places such as the lower portion of the rear tail panel can act just like a parachute. If you can reduce the amount of air going into the parachute, you should be better off.
2&3) The Datsun data showed that one of the biggest culprits in that case was the high windshield placed at a high angle. There was a huge pressure system right at the cowl. This makes a cowl induction system work, but it is bad for purposes of drag. There was also a lower pressure system created right above the roof because the air hitting the windshield would separate from the car body as it went up and over the car, promoting lift. By lowering the roof and raking the windshield, you can make for a smoother transition with less drag and possibly reduce lift.
In fact, the lower pressure system over the roofline in the stock-bodied Z is enough to open and raise the rear hatch at highway speeds if it is un-latched!
4) Rake will help to create downforce by helping to create a lower pressure system under the car relative to that going over the top of the car. Not sure how much it would change drag... but it may help just like in your first question.
5) The wheel wells is another "parachute" type of place in the car. I don't know if putting "extra" air into them via a brake duct will increase this effect, but a common solution is to add a vent at the rear of the wheel well to allow the air to escape more easily (like the Corvette).
6&7) When discussing aerodynamics, I have heard it said that the Datsun has "an enormous gaping maw." All the air flowing in there is just getting stuck in the engine bay. The firewall is another parachute type of place. In fact, I've seen pictures of old Zs with fiberglass hoods at even moderate speeds (80) and you can literally see the hood bulging up!
You theoretically want your grill opening to let in just enough air for your cooling system, and then you want to vent that air out from under the hood. Really, I don't think that reducing the grill size some will limit airflow enough to cause problems on most cars. Think about it, if your puller electric fan can only move... say... 2000cfm while you are idling around with no breeze to assist it, you probably don't need a grill opening big enough to flow 20,000 cfm. If you notice, many new cars have incredibly small grill openings compared to older cars.
As for routing the air out after it goes through the radiator, I think the GT-40 hood nostril is probably the best way to do this. Build air-tight ductwork to channel the air so that it only goes through the radiator (lines for brake ducts and such included) and then build another duct to route the air out from under the hood after it goes through the radiator.
To assist airflow through the radiator from a smaller opening, it might help though to tilt the radiator forward.
8) Much like in question 1, there are tons of places where the parachute effect can occur on the underside of the car. Making a smooth belly pan can reduce this effect. I have read however that on a smoother surface the air will better adhere to that surface by friction because there is nothing to agitate the air. Some people seem to think this will cause drag as well, but it seems like a step in the right direction anyway. Some advocate devices (such as vortex generators) to promote agitation as well to reduce friction.
9) The wider the car, the more frontal area, the more drag.
10) I do it too... I can sympathize!
I've actually found out that there is a wind tunnel facility very close to me... if the price isn't too bad (I imagine it is though...), I hope to someday test the Datsun there to see how well (or poorly) I did.John
08-18-2006 #3I've read that GM's wind tunnel measured a drag coefficient of .339 for the 1984 Z28,.299 for the Trans Am and .29 for the C5 Vette
Originally Posted by boodlefoof
I find this a bit hard to believe though
.35 for the Scion xB"There is no such thing as 'cheating'...it's called 'innovation'"
~Smokey Yunick
08-18-2006 #4
- Aug 2004
- Maine
- 594
I don't believe that number for the Scion either... that thing is a brick!
The coefficient for a 1990-96 Nissan 300ZX is .31John
08-19-2006 #5
- Aug 2004
- north central Iowa
- 503
