    Results 1 to 12 of 12
      Central Florida
      Engine Position-Tech Help Needed
      I have purchased both the S&P LS1 Engine Plates and the Holley LS1 Swap Plates to compare.
      Here is what I found: Compared to the S&P Plates, the Holley Plates move the engine back(closer to the firewall) by almost 1.25". However, the Holley Plates RAISE the engine by about 7/16".
      So the question is..When building a car for handling what is better:
      Engine forward but lower?
      or
      Engine back but higher?
      England
      back, the further the engine is to the centre the better also lower if poss
      Central Florida
      Quote Originally Posted by paul67
      I agree..however with the plates I have, I dont have the option of back and lower. So given the numbers above, which is the better of the two?
      Nov 2003
      Paradise, Ca
      1 1/4" engine setback won't make a damn bit of difference. I would opt for stock longitudinal location and down some.
      -Matt
      Quote Originally Posted by Matt@Lateral Dynamics
      I would think that 1 1/4 inches would make a difference considering your moving the transmission back the same distance.
      Maryland
      You may want to check header clearance before you make a desicion.That was the problem I found.Some mounts aren't real generous with steering box and frame clearance
      Central Florida
      Quote Originally Posted by 57hemicuda
      I am using the Holley/Hooker Long Tube LS1 headers which clear with either set of plates, however they are really tight with the S&P mounts (I had to demple one tube to clear the pitman arm). Clearance with the Holley Plates is not an issue.
      I am just trying to determine which set offers better overall weight distribution.
      England
      The plates that move the engine back.
      Apr 2003
      Nyköping, Sweden
      Country Flag: Sweden
      In the installation guide for LS1 engines that GM sells (#88959384) they have a drawing showing how the engine mounts should be located to get the backplane at the same location as an CSB engine.
      From seeing pictures of the Hooker plates I believe that they have done them according to the GM spec.
      The S&P plates are done the "easy" way and using one existing bolthole in the block and therefore moves the engine/trans forward.
      Jan
      Jan Suhr
      Nyköping, Sweden
      1969 Pro touring Camaro Z/28 LS1/T56
      Scandinavian Pro Touring Forum protouring.se
      Oct 2005
      SoCal
      In the terms of overall effect keep it LOWER.
      When you look at the change in weight distribution by moving the engine back 1 1/2" it doesn't do a damn thing. By comparison moving the battery to the trunk has a far more profound change in weight balance. To see any major benefit you need to move the engine 6-8" rearward.
      absecon, new jersey
      The plates i got for the vette put my motor 1 1/4 inch forward,so i had to move my 700 forward and remake the crossmember.The thing was i modified my hooker sidepipes to fit ls1 flanges ,when finished the sidepipes came out right in the right location,if i had set the motor back the 1 1/4 inch they wouldve been jambed up against my rear tires,so it helped me by using them.
      73 corvette chop top silver LS6 motor ,LS6 intake,700r4,2400 pro torque convertor ,3.70 gears,modified hooker sidepipes to fit LS1,17 x9.5 boyd starburst,nitto 275/50/17-255/50/17 tires,vb&p suspension,nitrous,L-88 headlights,autometer guages.L88 hood,flares,spreader bar,vb&p sway bars
      Central Florida
      Update
      FWIW,
      I welded up the Holley plates. Then drilled and tapped them to sit lower but in their original position (closer to the firewall).
      I ended up with plates that position the motor tight to the firewall (Holley's position) and Lower (S&P's position).
      The headers now have plenty of clearance.
