Results 101 to 112 of 112
05-05-2011 #101
Well, I'd been driving it a bit... hard usually... and it finally caught up with me too. My custom spec super quick spool turbo suddenly and violently frag'd and I mean bad. Some of the turbo is salvageable, but it makes more sense financially to buy a rebuilt replacement right now than rebuild that one again, so I basically got the same thing but without the upgraded turbine wheel. While I was at it, I figured I'd port out the E6 log manifold and match the turbine inlet. Should increase flow and decrease spool time, which means more power when and where I need it. A couple pics...
frag'd turbo:
new rebuilt turbo:
Pics of porting...
E6 manifold:
turbine before and after
I'm also going to take this time to re-do the intercooler plumbing, some of the cooling system plumbing, add an oil catch can, and install the EGT sensor (and maybe the wideband sensor as well), and clean up some other stuff. Car should be much better off for the hassle.
05-28-2011 #102Got it done... newly rebuilt turbo, ported manifold, re-did the IC plumbing, added an oil catch can, fresh ignition stuff, EGT sensor installed, relocated air intake and filter to fenderwell and fab'd a stupid simple splash guard, fixed coolant hose routing, and cleaned up some wiring and vac lines. It always rewarding to fix annoyances that have been bugging me for a while, and I really hated how much stuff I'd left sorta half done because of time constraints. It's extra nice to have both a garage and tools, and an alternate daily driver so I can work on the car as I want and get it done correctly. Anyway, some pics:
And button'd back up:
Now I'm just looking forward to getting it out to an auto-x event soon-ish.
05-29-2011 #103
