Results 21 to 40 of 112
08-31-2007 #21
Well my '70 Mach has been in mothballs for so long now it looks like I might have to redo some stuff to fix some problems from it just sitting. It's just plain too hot in Tampa in the summer to work on it.
But my XR4TI is making little bits of progress. Since it's my daily driver I can only do little things and bolt-ons because I really can't be without it a day. Most recently I did some maintenance stuff, replaced the high pressure turbo oil feed line, cut out the leaking gouged muffler, and cut a new grille (until my Cosworth grille finally comes). I've also bought a bunch of parts, including a gutted/ported intake set, the Cosworth turbine housing I mentioned, a billet fuel rail and AFPR, a nicely ported exhaust manifold, a set of ARE 16x7 wheels for auto-x days, and a few other bits and bobs.
Oh, and I got it to the dyno and got some mixed news. I should start by saying that I went to just confirm that the changes I made from last year resulted in the kind of improvement I anticipated, which they sorta did. So that is good. But there was some bad stuff too... First, the first dyno run was botched because my exhuast was rubbing on the rollers, so the subsequent runs were with the engine a bit heat soaked. Second, the clutch is going south. DAMMIT!!! It was obviously slipping on the dyno. And third, the afr went way way rich to 10.3 when boost came on and stayed rich around 11.5, which means I'm actually losing power because it's overly rich. Sure rich is great for preventing knocking, but it also kills power.
So it made a corrected 176hp/220tq with a slipping clutch, slightly heat soaked, and way rich, which is actually not all that bad, but it isn't the 210/240ish I was hoping for. And these numbers were on a Mustang dyno, which is the heartbreaker of dynos really. Still, the potential is there.
Anyway, a couple pics to show the grille and the dyno sheets:
08-31-2007 #22Slap a T3/T4, run 18-20psi! My bro built an '87 Turbocoupe motor and put it in an 87 LX Mustang 4 cyl car. He ended making 320hp wiht it. He front mounted the stock intercooler, ported the head, TB and intake manifold, fpr, tweaked the vam (not sure exactly what) and put a 3" downpipe and exhaust in it. It was such a cool car. Dummy sold the thing. It was killer! I can email pics. Just PM me or email me
Chris
[email protected]
09-01-2007 #23
