Thread: Clutch Fork Spring
06-17-2006 #1
Clutch Fork Spring
Hoping someone will chime in who owns a Camaro or Nova with a 502 and TKO 500-600. I recently bought my TKO600 from Classic Chevy 5 Speed and the compnay they order there clutch linkages and pedals was backordered on springs for the clutch fork. So when i get mine, where did any of you attach the spring to! I know one end goes to the fork and the other originally went to manifold studs, but I have headers and need to know what some of you did for attaching it to the block! What kind of bracket was required to fab up?
I know that some of you with the 502 had to buy Scoggin Dickeys ball stud braclet and I have done the same. And some of have spaced out the frame bracket for the Z bar but I am planning on having the center inch cut out of Z bar and welded back together for a lilttle cleaner look on the frame bracket. Thanks guys
Justin
73 Nova, 502 ci, TKO600, Mosier Eng 12 bolt, 6 point roll cage, Wilwood rear discs, factory front discs, 250 HP nitrous, subframe connectors, Slide-a-link trac bars, 17" Boyd Coddington Smoothie II's, and Hotchkis TVS kit.
07-03-2006 #2Hi Justin
You can fab up a spring and a steel rod (a heavy coat hanger will do). Bend the rod to form a hook for the fork end then a loop on the other end and hook the spring to anything handy. The thin rod will sneak through the tight spots without hitting anything. You may have to fab up a bracket or something to hook the spring to. I've seen stainless worm screw type hose clamps used on a header tube to form a mounting point or you may have a better spot that's more direct. As long as it doesn't touch anything to cause a rattle or scratch something expensive it should work fine.
07-03-2006 #3
07-06-2006 #4
